Author Topic: Model M Card to Base Initials Missing  (Read 1606 times)
Offline y11971alex
  • Looking for Toronto meetup
« on: Sat, 23 April 2016, 12:51:25 »
Of the ~10 Model M keyboards that have come into my hands, none of them had a "Card to Base" initialled.  Is there any clear reason why?
Re: Model M Card to Base Initials Missing
« Reply #1 on: Sat, 23 April 2016, 16:52:31 »
No idea why, but I think that the statute of limitations has run out on getting it remedied.
- D Trump 2026-10-24
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Sat, 23 April 2016, 17:26:43 »
I want to say "card to base" probably had something to do with the capsense boards where they had the soldered wires running from the controller to the PCB.  If that's screwed up it took some work to redo.
The stickers got reused for the M, and I'm guessing that test was folded into "merge", which may be the first test after the internals are put together.   Way easier to swap out an M controller and put the keyboard back in the line.
Just a guess though.
