Author Topic: The coating over pad printed keycaps...  (Read 5471 times)
Offline blueangel2323
« on: Sat, 23 April 2016, 14:33:00 »
Does anyone know what it is exactly? Some kind of UV-cured resin? Is it possible to DIY? Or are there DIY alternatives that are more durable?
Offline Nisei
Re: The coating over pad printed keycaps...
« Reply #1 on: Wed, 27 April 2016, 10:11:09 »
I'm also interested in this. Not to protect custom keys but because the way I type manages to mess up my backlit black keys (black painted transparent plastic) within a few months time.
A few years ago I was working in a factory where we printed tin cans (aerosols and paint cans) and after the sheets of tin were printed we put on a layer of special UV varnish which is very tough and scratch resistant.
I think I'm going to do some tests with transparent UV nail polish and cure it in one of those small curing lamps you can buy on eBay.
Offline Nisei
« Reply #2 on: Wed, 27 April 2016, 11:47:09 »
Just remembered I had taken some of the UV coating when I quit the job.
Here it is applied to an old Pause key next to an untreated Scroll Lock key.
As you can see it's become shiny but I believe there was matte coating available as well.
I've cured it in a UV nail polish curer and it's become as hard as glass!
Mind you, O haven't done a really neat job here. When applied with an airbrush or better brush it would probably look better.
Looks like a very resistant protection layer to me.
« Reply #3 on: Fri, 29 April 2016, 21:43:05 »
That's awesome! What is the coating called? Is it something the average person can buy?
Offline Nisei
« Reply #4 on: Sat, 30 April 2016, 06:10:26 »
Unfortunately I can't check it anymore. I think it was industrial-only. We received it in large barrels.
However, I think UV cured nail polish clear top coat is about the same stuff. It's also meant to protect against scratch and wear and available everywhere.
https://www.nailsuperstore.com/nail-products/elfa-non-yellow-uv-top-coat-32-oz/49632
Offline cookie
    • Deskthority
« Reply #5 on: Sat, 28 May 2016, 01:55:30 »
How about doubleshots with clear letters?
