Author Topic: BBC Micro style keycaps  (Read 3353 times)
Offline lrochfort
« on: Sun, 24 April 2016, 17:08:53 »
Hello all,
My first post here.
I'm wondering if there are any keycaps available that are similar to those found on the BBC Micro? I'm an Emacs user so I really only need a 60% or TKL keyboard.
I haven't got any further than that so far, but I would like the caps to fit onto keys that have a tactile click but are quiet.
Cheers,
Laurence.
Re: BBC Micro style keycaps
« Reply #1 on: Sun, 24 April 2016, 19:32:59 »
Welcome to Geekhack!
The BBC colourway comes up from time to time, but I don't recall anyone having actually made such a set.
It was discussed here a while back, and has some colour codes should you want to try to get something made.
Quiet tactile clicky switches are not common - you might be looking at something like Matias quiet click switches, which have Alps mounting, making it even more difficult to find a custom set to suit.
Offline lrochfort
« Reply #2 on: Mon, 25 April 2016, 03:23:35 »
Thanks very much, rowdy.
So, it sounds like the answer is either put my wallet where my mouth is or be less fussy?!
To be honest, whilst I'd love a replica of the Beeb keys, what I really would like is something similar to that key shape. I think it's similar to the selectric in many ways and I know there was a short run of the selectric modern keyset a while back.
Is there any commonly produced key cap with a similar shape to the Beeb keys?
« Reply #3 on: Mon, 25 April 2016, 22:18:12 »
One picture I found seems to show the BBC Micro had something like uniform SA profile keycaps.
The Modern Selectric set seems a fairly close match, but is a sculptured set, whereas I suspect the BBC had uniform profile keycaps.  It's been a very long time since I last used a BBC, and I cannot now recall.
