Author Topic: WKL B.87 Just stopped working  (Read 1645 times)
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« on: Mon, 25 April 2016, 17:19:49 »
Hey all. I am having an issue where my WKL B87 is not working. I plug the USB in and caps light flashes when the usb connector is about halfway in. I have tried it on this laptop and my desktop and it doesnt work. I have also tried different usb cables. Does anyone have a work around to this problem. It was bought by a fellow geekhack user and only used for a month or so, prior to that he had only about 1hr of use on it.
Please help!!
Offline trizkut
Re: WKL B.87 Just stopped working
« Reply #1 on: Mon, 25 April 2016, 17:21:34 »
You might have switched to PS/2 mode.  Try holding the 'U' key down while you're plugging it in.
  • Formerly Deeptek
« Reply #2 on: Mon, 25 April 2016, 17:24:04 »
Didnt work :-/ Im getting scared now. This is my only keyboard.. Unless I use this macbook.
Now the capslock didnt flash when I plug it in.
**Update.** I got it to work on my MAC with the hold U trick. But wont work with my Desktop. I will keep you posted with the status.
**Update 2** A reset of the PC worked. It wouldnt work in and USB until that. This Asus X99 Deluxe is a piece of junk. I have had to RMA 2 of them.. Ugh..
« Last Edit: Mon, 25 April 2016, 17:33:28 by Deeptek »
Offline LunarisDream
« Reply #3 on: Mon, 25 April 2016, 23:40:43 »
Whew. I was worried there for a moment because I thought it was my B.87.
Then I remembered I never sold you my B.87 and I'm typing on it right now.  :p
