Author Topic: zealios  (Read 2989 times)
Offline Jin
zealios
« on: Mon, 25 April 2016, 20:32:31 »
hi i just want to know any one know where to get zealios 65g ..... i will build new board
i used G80-1000 HAU 55G lubed vintage black , WYSE vintage black , MX blue ... vintage black was good but i just want other typing feeling
I saw Zealios are really smooth and good. i saw the R3 GB but cannot wait for june............................................
I also saw in originative but they only sell 70pc at a time , Zealpc is only sell 78g
Please help me to get Zealio 65g
Sorry for bad english .... :'(
Offline piemancoder
Re: zealios
« Reply #1 on: Mon, 25 April 2016, 22:00:12 »
Only way would be to either get them from the GB or from someone who has extras they are selling. The ones that Zeal sells on his website are all extras from the GB, and are more expensive. You could try and check the Classifieds often to see if anyone has any they want to sell. Good luck finding them :thumb:
Yoda grammar best has
Offline Jemaunji
Re: zealios
« Reply #2 on: Mon, 25 April 2016, 22:23:35 »
Zealpc.net R3 GB
Offline yomammary
Re: zealios
« Reply #3 on: Tue, 26 April 2016, 09:04:59 »
RF 87u 55g | Leeku 1800
Offline alienman82
Re: zealios
« Reply #4 on: Tue, 26 April 2016, 10:37:12 »
removed.
« Last Edit: Thu, 01 March 2018, 15:25:23 by alienman82 »
Offline Jin
Re: zealios
« Reply #5 on: Tue, 26 April 2016, 12:18:39 »
since I actually read the OP, try to make a post on reddit.com/r/mechmarket  Pretty sure you'll be able to get a seller to get you some
thanks but i dont like mech market , plus Modertor
Offline Waateva
Re: zealios
« Reply #6 on: Tue, 26 April 2016, 12:50:48 »
Then your only option is to put up something in the classified thread here on GH and hope someone will sell them to you.
Offline jerue
  • (Whenever that happens :P)
Re: zealios
« Reply #7 on: Tue, 26 April 2016, 13:04:33 »
Honestly, the best bet (given the time constraint) would really be to just buy 140 from Originative and sell off the remainders (which at the right price will not be hard to do). $1/switch isn't cheap but factoring in the must-have before June is reasonable. Sherry is shipping once a week as he's away in China, but you should have them by then.
Offline Jin
Re: zealios
« Reply #8 on: Tue, 26 April 2016, 15:12:56 »
Thankyou , that will be good too.....
Offline Anole
Re: zealios
« Reply #9 on: Tue, 26 April 2016, 19:15:10 »
Buy them over at:https://zealpc.net/collections/group-buy-pre-orders/products/zealio
Offline GiveCandyy
Re: zealios
« Reply #10 on: Wed, 27 April 2016, 04:52:06 »
I wish it wasn't soon
