Author Topic: Trouble changing Cherry MX switches on PCB mounted board  (Read 1711 times)
Offline MrFex
« on: Tue, 26 April 2016, 13:48:50 »
Hi -
I wanted to see if I can replace the switches on a Cherry MX Red. It is supposed to be easy on this particular board because it was designed by community members for this exact purpose. For some reason though I cannot remove the switch. I've used some thin pliers to nudge the small tabs but the top of the switch seems stuck on the top part. I wonder if the LED is the culprit. Do you have any tips?
I really LOVE my Cherry MX Blacks and I wish I could replace these reds with blacks. The board is a KBT Vortex RACE. See picture
« Last Edit: Tue, 26 April 2016, 16:54:14 by MrFex »
Offline joey
Re: Trouble changing Cherry MX switches on PCB mounted board
« Reply #1 on: Tue, 26 April 2016, 13:54:11 »
The LEDs stop the switch top being removed. You'd have to desolder and remove them.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Tue, 26 April 2016, 13:55:33 »
Yes you definitely have to de-solder the LED light off.  However after that you should be able to pop the top casing off without de-soldering the switch.
EDIT:  Other guy beat me to it.
Offline merlin64
    • MechMerlin
« Reply #3 on: Tue, 26 April 2016, 14:25:13 »
You can putting in sip sockets while you're at it. That way you can swap out the LEDs whenever you want. Just make sure the resistor values still work.
« Reply #4 on: Tue, 26 April 2016, 14:30:09 »
You can also clip the top of the switch housing where the LED is to allow the top to come off without desoldering next time.
Offline MrFex
« Reply #5 on: Tue, 26 April 2016, 16:54:01 »
Thanks for the replies. I was hoping I didn't have to solder, I'm afraid to damage it because I have very limited soldering skills. Ah well, maybe I'll change my mind. I know I will probably never find another Race, man I wish for more 75% next christmas  ^-^
Offline Anole
« Reply #6 on: Tue, 26 April 2016, 19:37:16 »
Yup, those LEDs need to be desoldered  :(
