Author Topic: A quick look on my first mech, a Cooler Master Storm QuickFire Rapid.  (Read 7624 times)
Offline Boundl3ss
Pics: http://imgur.com/a/YdvHt
amazon: http://www.amazon.com/Storm-QuickFire-Rapid-Tenkeyless-Mechanical/dp/B007VDKLLM?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
So, for my first mechanical Keyboard I decided to purchase a Cooler Master Storm due to many recommendations from many people. I decided to go with MX browns due to them being my favorite switch that I tried out in store. Upgrading from a membrane this feels amazing(As I am currently typing on it). The build quality is solid, the keyboard looks nice, and it feels soo good. The included key caps are a nice touch also. After only owning it for a very short period of time, I have done two things: added O-rings and flipped the spacebar. I recommend others to try both of these  things out because in my opinion it improves the experience. I may not have any other mechs to compare this to, but it feels damn good. I would definitely recommend this keyboard to others, and I probably will be modding it in the future.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: A quick look on my first mech, a Cooler Master Storm QuickFire Rapid.
« Reply #1 on: Wed, 27 April 2016, 22:34:23 »
Moved this to the Reviews sub-forum.
Congrats on your first mech! :thumb:
Depending on your usage, give the browns some time and it will feel smoother as the stems wear.  What other mods do you have planned?  Lubing the switches perhaps?
Offline Boundl3ss
« Reply #2 on: Wed, 27 April 2016, 22:37:55 »
Sorry! didn't even see reviews as a sub-forum.
I am planning to paint the casing/plasti dip it and also get a custom set of keycaps.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #3 on: Thu, 28 April 2016, 04:01:36 »
No worries.
Ah plastidip. :thumb: I tried that on my previous Shine II.  It didn't hold up too well in the corners from coming in contact with the plastic keyboard roof.  However, I may not have allowed proper curing time between layers.
Anyway, here's a tip, if you have plastidip stuck in the nooks and crannies, WD-40 will dissolves it so you can brush or wash it off.
« Reply #4 on: Thu, 28 April 2016, 05:27:36 »
What happened to the space bar?
Offline Boundl3ss
« Reply #5 on: Thu, 28 April 2016, 18:50:26 »
Reversed it.
Offline loomin
  • I don't know much
« Reply #7 on: Fri, 29 April 2016, 00:25:31 »
Why do people reverse their space bars? I've tried it before and it felt very awkward to use.
« Reply #8 on: Fri, 29 April 2016, 00:30:41 »
There is a recent discussion upon that very subject.
