Author Topic: Can we color PBT caps?  (Read 2088 times)
Offline Erzegovaz
« on: Thu, 28 April 2016, 15:21:16 »
Hi guys :D new question here :D
I`m searching a spacebar for my fc660m old model, but it`s impossibile to find. And the mod with glue is not easy to do well. So i`m thinking...is it possibile to color PBT keycaps? I really want a perfect green or white spacebar  ;D
Offline rpeterclark
  • RPTR ❌
Re: Can we color PBT caps?
« Reply #1 on: Thu, 28 April 2016, 15:29:37 »
You can! There are guides for it https://imgur.com/a/P6RHv . You might have a hard time getting the *exact* color you want without some experimentation.
Offline Erzegovaz
« Reply #2 on: Thu, 28 April 2016, 16:51:38 »
wuooooo very coool! :D And the new color cover totally the old? bcs i have a grey set, but i hate...
My PBT caps (leop) are rough and porous, should I polish with sand paper?
Ty man
Offline piemancoder
« Reply #3 on: Thu, 28 April 2016, 17:03:48 »
I wouln't try and use sandpaper to change the feel of caps. Just get some ABS caps or a smoother PBT set.
Yoda grammar best has
Offline Erzegovaz
« Reply #4 on: Sat, 30 April 2016, 04:05:15 »
other tips guys? :D
Offline losing_ctrl
« Reply #5 on: Sat, 30 April 2016, 09:22:15 »
Great link, thx for sharing. I think I need to give this a try with my HHKB.
« Reply #6 on: Sat, 30 April 2016, 09:45:50 »
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
