Author Topic: Cleaning your artisan key caps & Blanks  (Read 8670 times)
Offline mrlooolz
« on: Sun, 01 May 2016, 06:24:35 »
Hey I traded some key caps and some that I got are a little dirty. How do I wipe down the caps with out destroying them? I got some 40% alcohol solution. Some places are hard to reach (e.g. the nose in clack skulls) others I am just not sure if the alcohol would destroy any coats (e.g 2 white Gateron PBT blanks) anyone can share some of their insights?
Ducky Shine 5 w Mx Browns  | White fox w Zelio's purple 67g | Gateron Blank set
Current Aims: Jack O Lantern is my end game cap. Looking for one.
                                                   --> MrLooolz's Classified. <--
Re: Cleaning your artisan key caps & Blanks
« Reply #1 on: Sun, 01 May 2016, 21:56:56 »
Soak with denture cleaner?
Offline rurushu
« Reply #2 on: Sun, 01 May 2016, 23:15:23 »
+1
You can search around in GH, there are people using warm water bath with denture tabs that are used to clean bracers etc.
Offline raymogi
« Reply #3 on: Sun, 01 May 2016, 23:17:46 »
Been telling this to everyone, use your spit. I've been doing it for all my artisans :D
Please feed my addiction.
Offline rurushu
« Reply #4 on: Sun, 01 May 2016, 23:19:10 »
Wha??? For real?!  :eek:
I for one, definitely wouldnt want my caps soaked in my spit.. gross af
Offline raymogi
« Reply #5 on: Sun, 01 May 2016, 23:22:26 »
No one said anything about soaking. What I've been doing is put a little spit on the edge of a micro fiber cloth and clean the affected area. Works every single time.
« Reply #6 on: Sun, 01 May 2016, 23:27:08 »
Note to self: ensure biological safety precautions are followed when buying keycaps from raymogi :p
Offline rurushu
« Reply #7 on: Sun, 01 May 2016, 23:27:33 »
Okay.... but still... spit...
My inner janitor would never allowed that...
Offline -musubi
  • Spam rice 'n eggs
« Reply #8 on: Sun, 01 May 2016, 23:45:01 »
Not sure if I'd back up the spit method  :)) but what I usually do is just do a quick rinse under the sink, not too cold or hot, and then pat it down with a towel and let it air dry. I've heard the denture tab method works fine as well (probably ACTUALLY cleans it).
Offline Michael
  • Formerly Bro Caps
« Reply #9 on: Sun, 01 May 2016, 23:46:38 »
Offline raymogi
« Reply #10 on: Sun, 01 May 2016, 23:47:18 »
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #11 on: Sun, 01 May 2016, 23:52:06 »
i use a toothbrush and mild dishwashing liquid.
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
« Reply #12 on: Mon, 02 May 2016, 01:05:54 »
Photographers generally breathe on their lenses and wipe away the moisture with microfiber cloths, you could try cleaning any delicate artisan keycaps you have similarly. Alternatively you may be able to pick up isopropyl alcohol from your local pharmacy, just tell them its for cleaning purposes.
May all your key presses strike true.
  Choc Mini         HHKB
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #13 on: Mon, 02 May 2016, 02:15:07 »
I soak in dishwashing soap, clean with water, get my favorite DKCT (dedicated keyboard cleaning toothbrush) and make sure they are spotless! Even painted caps like the old Iron Mask's from HKP are free from harm in that process :)
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline rurushu
« Reply #14 on: Mon, 02 May 2016, 10:09:40 »
God... the constant flashing of the pic... is making me blind...  :-X
Guys, if you use brushes, arent you afraid that it might scratches/ bruises/ blemishes the caps?  :eek:
« Reply #15 on: Mon, 02 May 2016, 21:31:04 »
It would have to be a pretty stiff brush!
Like a wire brush :eek:
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #16 on: Mon, 02 May 2016, 21:46:12 »
Note to self: Don't buy any artisans from Raymogi.
Offline rurushu
« Reply #17 on: Mon, 02 May 2016, 23:07:19 »
or we can sterilize them after we bought/ tradeded with Raymogi  ;D
« Reply #18 on: Tue, 03 May 2016, 13:19:51 »
Y'all dirty af
Offline rurushu
« Reply #19 on: Tue, 03 May 2016, 21:31:17 »
Y'all dirty af
how do you clean your artisans demik?
Offline beehatch
  • baehatch
« Reply #20 on: Tue, 03 May 2016, 21:38:47 »
« Reply #21 on: Tue, 03 May 2016, 23:05:40 »
Y'all dirty af
with demilk
i have no idea why i even posted here. my **** posting is out of control
also i clean my caps by not touching them
« Reply #22 on: Tue, 03 May 2016, 23:56:23 »
Y'all dirty af
with demilk
Mentiroso. You posted a pic of you cleaning the HHKB tour board.
Offline mrlooolz
« Reply #23 on: Tue, 03 May 2016, 23:58:35 »
Thanks ya'll. I used some diluted dish washer soap with a fine hair tooth brush. Worked like a charm  ^-^
« Reply #24 on: Wed, 04 May 2016, 01:08:07 »
Y'all dirty af
with demilk
Except that Ribbit you had on your D.
That would need some cleaning.
Offline beehatch
  • baehatch
« Reply #25 on: Wed, 04 May 2016, 08:14:39 »
Y'all dirty af
with demilk
OnO I cleaned it
Offline rurushu
« Reply #26 on: Wed, 04 May 2016, 09:29:27 »
Y'all dirty af
with demilk
So... err... Beehatch uses demik to clean caps and demik cleans them by not touching?
Something's not connecting here.... must be my imagination...
Y'all dirty af
with demilk
need to ask alienman how he cleans his Ribbit, he puts it in his mouth after all, must be hygienic I think...
