Author Topic: 40% Layout  (Read 4634 times)
Offline Anole
40% Layout
« on: Mon, 02 May 2016, 10:50:22 »
I'm working on making my own 40% keyboard. I am thinking about using this layout, do you guys have any suggestions or comments on it?
« Last Edit: Tue, 10 May 2016, 20:41:52 by Anole »
Offline 3K
Re: 40% Layout
« Reply #1 on: Mon, 02 May 2016, 10:57:13 »
It looks cute! But I'd suggest to choose a standard key size as spacebar. A 5u spacebar will render the board incompatible with most keycap sets.
Offline Anole
Re: 40% Layout
« Reply #2 on: Mon, 02 May 2016, 11:32:16 »
Thank you for the feedback! I see your point, it would be best to use standard sized keycaps  :D
Re: 40% Layout
« Reply #3 on: Mon, 02 May 2016, 22:09:35 »
This board my friend and I designed seems right up your alley as far as layout goes, the only changes are a few key sizes and a split space.
Offline alexjd99
  • oozing through the cells of one's own construction
Re: 40% Layout
« Reply #4 on: Mon, 02 May 2016, 22:16:17 »
Here's my layout for my HHKB Golbat that should be coming soon (mind the symbols, I forgot those are a no go with TKG)
Here's my layout for my Planck (num pad layer key will be an MX lock switch soon)
Fn
Fn 2
Fn 3 (num pad layer)
I'm sure you can get some ideas from that :))
« Last Edit: Mon, 02 May 2016, 23:21:16 by alexjd99 »
Offline decker
Re: 40% Layout
« Reply #5 on: Tue, 03 May 2016, 01:24:09 »
One idea I had was to limit the mod keys to 3.
Combining them would give missing keys :
100 shift
010 ctrl
001 alt
110 win
101 hyper
011 alt gr
111 fn
Note that on regular kb win can be obtained by Ctrl+Esc and Alt Gr by Ctrl+Alt...
About your layout, I'd remove one or both of the Fn keys and the caps lock.
Add Esc and more symbols...
Offline Anole
Re: 40% Layout
« Reply #6 on: Tue, 03 May 2016, 07:20:41 »
Thanks, this looks great!
Offline Anole
Re: 40% Layout
« Reply #7 on: Tue, 03 May 2016, 12:52:17 »
I revised the layout. It now uses standard sized keys that are all in their native rows, except for the backspace, which is not in its correct row  :(.
Offline Anole
Re: 40% Layout
« Reply #8 on: Tue, 10 May 2016, 20:42:25 »
Bump. I edited the original. Please tell me what you think!
Offline alexjd99
Re: 40% Layout
« Reply #9 on: Tue, 10 May 2016, 22:45:01 »
My only new recommendations would be to replace caps with tab, but swap caps and control, and add an esc (so from top to bottom it would go Esc, control, shift, and tab). Control and caps swapping is the greatest thing you will ever try. And on minimalist boards, it's better to have keys that are less frequently used on a function layer (I would just use FN+Tab for caps)
