Author Topic: What keycap profile does Filco Majestouch 2 Ninja use?  (Read 6762 times)
Offline Growgor
« on: Tue, 03 May 2016, 02:02:22 »
What the topic says.
Thank's in advance!
Grow
“Imagination is more important than knowledge. For knowledge is limited to all we now know and understand, while imagination embraces the entire world, and all there ever will be to know and understand.”
Offline KnivesM
Re: What keycap profile does Filco Majestouch 2 Ninja use?
« Reply #1 on: Tue, 03 May 2016, 02:08:28 »
Step-Sculpture 2 which is similar to Cherry.
Others
Offline Growgor
« Reply #2 on: Tue, 03 May 2016, 02:19:36 »
So pro!
Thank you sensei.
Offline rurushu
« Reply #3 on: Tue, 03 May 2016, 03:53:26 »
I only knew the heights of the caps, didnt knew the sculpts.
thanks Knives  :thumb:
« Reply #4 on: Tue, 03 May 2016, 06:35:06 »
I think you've got Filco and Leopold confused there.
Filco caps are what people typically refer to as OEM it is higher than cherry profile.
Step-Sculpture 2 is the profile Leopold uses and it is very similar to cherry profile.
Tons of info here http://reddit.com/r/MechanicalKeyboards/wiki/keycap_guides
« Last Edit: Tue, 03 May 2016, 06:45:55 by SpAmRaY »
Offline KnivesM
« Reply #5 on: Tue, 03 May 2016, 07:45:51 »
I thought I remembered it being OEM but looked up some listings and they all said step-sculpture 2 so I figured they had changed.
Found Jokriks comparison of Leopold, Filco and Kul and you are right though. My bad.
Others
