Author Topic: Does anyone have diagrams/pin specs for the SMK/Monterey Alps-like switch?  (Read 4525 times)
Offline dante
BlueNalgene is taking interest checks on a new project: https://geekhack.org/index.php?topic=81608.0
SMK/Monterey compatibility may be possible but info on this is pretty limited.  Can anyone one chime in?
« Last Edit: Tue, 03 May 2016, 12:20:37 by dante »
Offline mike52787
  • Alps Aficionado
I can help, I have a whole tray of smk monterey blues on my desk atm. Would you like me to send you one?
Offline dante
I sent a message to BlueNalgene - waiting to hear back from him.
https://geekhack.org/index.php?topic=81608.msg2161238#msg2161238
Offline mike52787
  • Alps Aficionado
Here is some images too, they may help you out a bit. The shape is considerably different and the pins are also different. I will respect anyone exponentially more if they get a alps AND smk pcb worked out.
agan, since the shapes are so different, same with the plates.
Dont be shy about asking for a switch to check dimensions and stuff, ive got plenty.
Offline BlueNalgene
Sweet Mike.  I think that pic of the bottom of the switches might be enough for me to figure out the placement for the holes.
Offline mike52787
  • Alps Aficionado
If you can figure this out, count me in for a tkl pcb. super excited about this project, finally alps gets the love it always deserved!
Offline BlueNalgene
Check my work
The SMK set is at (x,y in mm):
(-3.15, 5.75) and (3.15, 4.5) from the centroid pictured.
Using a standard Cartesian plane, not that backwards **** KiCAD uses.
The blue square is the 14x14mm cutout.
I don't think the tenkey I made will be able to handle this modification since the USB hub wiring takes up a lot of space.  However, it might work for the TKL.
Offline mike52787
  • Alps Aficionado
Holy **** man, you are a genius. from my measurements it seems to be right.  I am really excited for this project!
Offline Jokrik
Oh wow I'll be watching this, been planning to hardwire my monterey but having plate problems
Offline mike52787
  • Alps Aficionado
Let me guess, you dont like big ass enter and 1u backspace? :p I had the same problem with my monterey plate, as seen in one of my images eariler.
Offline Jokrik
I'm having a hard time finding a plate which fits the Monterey, stabilizer and keycaps is no problem as it can be found online
