Author Topic: First Attempt  (Read 3800 times)
Offline kingyachan
First Attempt
« on: Tue, 03 May 2016, 23:40:05 »
Hey there!
this is my first attempt at the design I'd like.
http://imgur.com/GIT1WWY
Now I'm still pretty new to this so I'm not super sure if I've made any glaring mistakes, I think I used standard sized caps and stuff but I could be wrong, is there anything really wrong with this design? any problems I would come across?
« Last Edit: Tue, 03 May 2016, 23:44:25 by kingyachan »
Offline Kenda
Re: First Attempt
« Reply #1 on: Tue, 03 May 2016, 23:41:37 »
Hey photo can't be loaded, can you re-up?
Offline kingyachan
Re: First Attempt
« Reply #2 on: Tue, 03 May 2016, 23:45:53 »
changed to link, sorry about that!
Offline ineph
  • nostalgic procrastinator
  • Do you know the Venus Project??
Re: First Attempt
« Reply #3 on: Tue, 03 May 2016, 23:57:16 »
this kinda of layout is optimized to do what?
Bla bla bla Stealthbla bla Blue
Offline kingyachan
Re: First Attempt
« Reply #4 on: Wed, 04 May 2016, 00:02:57 »
I wouldn't say its optimal for anything in particular, just what I want in a Keyboard, purely a personal set up  :p
Offline ineph
Re: First Attempt
« Reply #5 on: Wed, 04 May 2016, 00:19:09 »
it's does not look very operative for me, but like you say, it is personal :thumb:
and about the other layers?
Offline kingyachan
Re: First Attempt
« Reply #6 on: Wed, 04 May 2016, 00:24:53 »
Hadn't figured out the other layers just yet, I have a basic idea though.
will I have any issues with cap compatibility though?
Offline Michael
  • Formerly Bro Caps
Re: First Attempt
« Reply #7 on: Wed, 04 May 2016, 00:36:21 »
Pretty 'fucn' cool  :thumb:
Offline ineph
Re: First Attempt
« Reply #8 on: Wed, 04 May 2016, 00:39:45 »
since is a very personal layout, I pretty sure you will not find any full set of caps compatible, but I have only a few months as mechanical keyboards enthusiast so I can be wrong :rolleyes:
Re: First Attempt
« Reply #9 on: Wed, 04 May 2016, 01:56:59 »
What caps are you hoping to get?  If you're fine with a uniform profile (DSA, G20 or SA row 3) and wrong legends or blanks you'll be able to cover it.  If you want legends these will be a problem
Escape
Tab (always 1.5u)
Left shift (1.25u ISO or 1.75u usually used for a split right shift)
Enter (usually 2.25u)
If you swapped Esc and backspace to ISO enter keys (Esc upsidedown) I think you'd be perfect for caps and the numbers would be nearer normal stagger, but it would be a bit bigger...
Interesting design :thumb:
Offline kingyachan
Re: First Attempt
« Reply #10 on: Wed, 04 May 2016, 02:38:48 »
HA! silly typo, whoops.
Escape
Tab (always 1.5u)
I wouldn't be to upset about blanks, I kinda like that idea actually.
Also I've changed it up, here is v2
http://imgur.com/k4vQEXF
Is it going to feel super weird if the numbers are not staggered?
Re: First Attempt
« Reply #11 on: Wed, 04 May 2016, 02:49:13 »
Well the numbers are only half where your fingers expect them to be, so until you adjust you'll probably hit the one next door as well.  How you adjust is personal - I can move backspace with no problem (to caps lock or a split space bar), but I cannot adjust to an ANSI enter.  You'll never know until you try :)
