Author Topic: Corsair and Coolermaster: what a good Cherry kb should feel like?  (Read 3122 times)
Offline nick[0]
Hi,
Because my Model M SSK has started glitching and needs to be repaired, I've started looking into Cherry keyboards.  I was fortunate enough to be able to try out MX red, black, blue, brown, and maybe greens at a local store.  Do Corsair and Coolermaster make keyboards that do a good job showcasing what a cherry MX-based keyboard should feel like?
With the exception of the red, all of them felt high friction and slow, and kind of like a dirty and worn out stair-climbing machine.  The blue was better, but to use the stair-climbing machine metaphor:  this one was smooth, but it was like someone was hitting you in the ankles with a stick to tell you to pick your leg up...with every step! ;-)  Seriously, I found it very disturbing!
What really surprised me was the only one I liked was the "DEVASTATOR II" which felt a really nice rubber dome.  Is that kind of like what a 45g Topre feels like?
Offline quasistellar
Re: Corsair and Coolermaster: what a good Cherry kb should feel like?
« Reply #1 on: Thu, 05 May 2016, 18:30:10 »
Buckling spring to any Cherry MX is a downgrade for you in my opinion.
If you want something g comparable in quality and feel to your SSK, you'll probably have to step up to a 55g Realforce.
 I say 55g since you're probably used to a heavier switch now.
Or, just fix your SSK :P
Offline klennkellon
  • I like bottoming out
« Reply #2 on: Thu, 05 May 2016, 22:15:54 »
I have to agree with this, no Cherry really matches buckling springs.
Linear ALPS are very good if you want to try linear, and of course 55g Topre is great.
Offline shortround
  • Scoot jockey, nomad trash.
« Reply #3 on: Thu, 05 May 2016, 22:35:35 »
You should maybe look into Unicomp boards.
Offline FrostyToast
  • Litshoard
« Reply #4 on: Thu, 05 May 2016, 23:17:43 »
I would say Model M buckling springs more like climbing a set of stairs as it's sluggish but has a nice smooth motion.
Then tactile Cherry is quick with little resistance but does catch on the upstroke like running through a forest riddled with roots.
And Topre needs no metaphor. They're just high quality domes.
Quote from: elton5354
« Reply #5 on: Fri, 06 May 2016, 08:04:54 »
That might be the best suggestion. I keep forgetting about them.
Offline klennkellon
« Reply #6 on: Fri, 06 May 2016, 13:03:58 »
Alternatively, for $45 Phosphor will completely refurbish your Model M.
http://phosphorglow.net/
« Reply #7 on: Sun, 08 May 2016, 04:44:13 »
+1
Really.
Comes out better than new.
Offline carmenohio
« Reply #8 on: Sun, 08 May 2016, 09:56:53 »
I agree with everyone else, but if you do decide on getting a Cherry MX, do not get a Corsair.  Corsair keyboards do not have a standard bottom row, and don't buy into Corsair's bull**** marketing about how their keyboard is a premium product because they have an aluminum top plate, and everyone else has plastic.  Most Cherry MX keyboards are mounted to a metal plate, and have a plastic protective cover on top.  In actuality, Corsair's product is cheaper because they are leaving out a part (the protective top cover).
Offline FrostyToast
  • Litshoard
« Reply #9 on: Sun, 08 May 2016, 09:59:51 »
Didn't realise you said ssk.
You could try and build an F SSK.
Or you could just repair the ssk and be happy with you life.
Offline Darkshado
« Reply #10 on: Sun, 08 May 2016, 20:16:15 »
My understanding is that the OP needs something to tide him over until his SSK is fixed.
Depending on how time sensitive the situation is: either a full size Unicomp, or a locally sourced keyboard with (probably) MX switches. (Maybe a fellow GH'er local to him could lend something?)
That Cooler Master Devastator II is a "slider over membrane" keyboard: it has a plastic slider on top of a rubber dome that still needs to be fully depressed to actuate the switch. In this case, the slider is compatible with MX keycaps.
Offline FrostyToast
  • Litshoard
« Reply #11 on: Sun, 08 May 2016, 21:07:35 »
If you're buying a keyboard, don't buy more of the same.
Get something different or else it's a waste of money.
Offline opensecret
  • 公开的秘密
« Reply #12 on: Tue, 10 May 2016, 23:07:31 »
Corsair boards don't get much love on Geekhack, but I'm very happy with the K95 that I own. With o-ringed Cherry reds, it's quiet and feels light and precise.  (I also get a lot of use of the 18 macro keys on that board.)  I have a Model M, but I gave it to my wife because it feels heavy to me.  I've also got Topre (Realforce) and Alps (Northgate and Matthias) boards that I use regularly.  There's no one board that I think is superior to all other, and I enjoy variety in many things, including keyboards.
IBM Model M |Matias Mini Quiet Pro|Plum 84EC-S|RealForce 103U-UW & 87U-UW|Omnikey Ultra T| 2 Omnikey Ultras| WASD V2| Xmit Hall Effect|
