Author Topic: Need help with ergodox RGB mod.  (Read 2271 times)
Offline climbalima
  • likes building stuff
« on: Thu, 05 May 2016, 21:39:13 »
Hi there! My teacher gave me a large amount of ws2812b led strip too play around with, so i have been adding them to all my keyboard builds! I have run into the issue of the teensy 2! I have gotten the rgb to work on all of my pro micro builds, but none of my teensy 2 ones. It appears to be an eeprom issue seeing as the lighting preferences are not saved and that I have to turn backlighting on every time the keyboard is plugged in. It also refuses to do any effects and can only display one color at a time. Thank you!
My code is here:
https://github.com/climbalima/Split_QMK/tree/master/keyboard/ergodox_ez
