Author Topic: Keyboard with Costar Stabs  (Read 3051 times)
Offline Erzegovaz
« on: Thu, 12 May 2016, 11:05:23 »
Hi guys, i`m searching a great keyboard for a friend and he want absolutely a keyboard with Costar stabs TLK or 60%.
I know only FILCO keyboard, but cost so much (150 euros here), without detechable cable and with bad keycaps.
Any tips?
Thanks :D
Offline Saiph
Re: Keyboard with Costar Stabs
« Reply #1 on: Thu, 12 May 2016, 11:35:25 »
Any tips?
Thanks :D
WASD keyboards use costar stabilizers as well. It doesn't have good keycaps but it does have a detachable  cable.
Offline Erzegovaz
« Reply #2 on: Thu, 12 May 2016, 13:52:58 »
Any tips?
Thanks :D
Thank you. The problem with WASD is the shipping...cant find a WASD in EU. =(
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Thu, 12 May 2016, 15:14:12 »
CM Storm QuickFire Rapid or QuickFire Stealth are probably your best bet.
Otherwise you should just bit the bullet and buy a Filco, to be honest they're still one of the best keyboards around.
Keycap is preference and you can always change it later (Personally I don't like PBT).
Offline Erzegovaz
« Reply #4 on: Thu, 12 May 2016, 15:20:13 »
Yes I was thinking at cm storm rapid, but now is scarce...cant find in ordinary store (they have all the rapid-i) =(
I think the problem with filco is the cable. Detechable cable is more more more confortable, why filco made this no-detechable? Are there some specific reason u know? mmmh
