Author Topic: I need help, I don't have the knowledge to make a PCB.  (Read 2922 times)
Offline Bonk_Donk
« on: Sat, 14 May 2016, 19:24:23 »
I'm trying to create a custom keyboard that can have its PCB as freeware for anyone who wants to make it as well, the issue is that I have no idea how to create the PCB as I don't have the proper programs or knowledge to make it. I've tried the Clueboard Kalerator program but it does not work on free EAGLE software and is known to be buggy on even paid software.
Is there anyone with the knowledge, or even willing to help create a PCB blueprint that I can upload to a company and have made?
This is the keyboard : http://www.keyboard-layout-editor.com/#/gists/c7dce418c8d8dd65e18dcb238d1d297e
Also I am extremely new to Geekhack so, Hi!
Offline sircheddar
Re: I need help, I don't have the knowledge to make a PCB.
« Reply #1 on: Wed, 01 June 2016, 21:37:48 »
hey dude, just wanted to throw in my very minimal and uneducated experience. your layout is so close to a b mini from winkeyless that yoiu will probably spend 25 x the amount of time and 3x the cost to make yours, compared to a b mini layout. which would take like 2 weeks from project start to finish as well!
" I hope that when the world comes to an end, I can breathe a sigh of relief, because there will be so much to look forward to. "
Offline Data
« Reply #2 on: Thu, 02 June 2016, 07:36:11 »
Welcome, Bonk_Donk.  I'm not sure if you fully realize what you're asking for here.  Creating a functioning PCB is a lot of work.  You might be better off hand-wiring that layout to a Teensy, to be honest.  You can use Swill's plate builder to get started -- have a plate cut in acrylic or another inexpensive material so you can test it out.
http://builder.swillkb.com/
Offline hanya
« Reply #3 on: Thu, 02 June 2016, 09:26:18 »
It seems DSA 6.5u spacebar is not popular.
PFU HHKB JP, Sanwa MA-TB38 trackball
Offline sircheddar
« Reply #4 on: Sun, 05 June 2016, 21:56:23 »
yeah... that as well. actually, pretty sure it doesnt exist
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sun, 05 June 2016, 23:57:13 »
It exists for Cherry MX DSA (http://pimpmykeyboard.com/dsa-spacebars-pack-of-1/) but I'm not sure about ALPS mount, I could only find 6u for ALPS atm.
Very nice looking compact layout Bonk_Donk. I've seen a few 75% layouts that look pretty similar; not the same but close, I guess. Winkeyless's B.Mini, Duck Octagon 75%, Gons NS NerD MX-Mini, and Noppoo Choc Mini (Noppoo = Cherry or Gateron). Hand wiring seems to be the first step for most makers here. I hope to read your build log in the future if you do decide to stick with it :)
