Author Topic: Looking for standard 6GV2 en-us keycaps  (Read 5472 times)
Offline philberndt
« on: Sun, 15 May 2016, 13:56:57 »
Hello I am new to this forum!, I live in Norway and obviously you can buy mostly Nordic keyboards, but the fact that I dont speak Norwegian and I communicate 99% in English for work has me hunting for en-us keycaps for the Steelseries 6GV2.. unfortunately.. because of the layout of this keyboard, they are really hard to find. Anyone can push me in the right direction?
p.s.: I have been a lurker for some time... you guys have nice stuff.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Looking for standard 6GV2 en-us keycaps
« Reply #1 on: Sun, 15 May 2016, 14:53:36 »
I have no idea of how available they are to you but the universal keysets by max keyboards are offered up in a few variants (black blank, side printed black/white, and top printed black/white). The universal set should cover your 1.25u left shift, 1.75u right shift, and the big ass enter key. Man, I'm almost 100% positive that the left shift is 1.25u. Hard to tell with that picture. That is one challenging layout!
http://www.maxkeyboard.com/products/cherry-mx-keycap/iso-layout-keycap-set/ The universal sets have that voluptuous enter key
Offline philberndt
« Reply #2 on: Sun, 15 May 2016, 14:58:11 »
it seems that the big ass enter key is different on max, I took a look at it before. This is the layout, I have no clue what it means...
EDIT: I found this also https://geekhack.org/index.php?topic=57866.0
« Last Edit: Sun, 15 May 2016, 15:13:25 by philberndt »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Sun, 15 May 2016, 15:23:03 »
Looks right, hmmm that picture is missing a bunch of the keys though. If you check out the universal set you'll notice that the set is in two sections. The second section has all the non-standard keys. According to Deskthority a normal Big ass enter key is 1.5u x 2.25u (top/bottom) or ~29mm x 43mm. So if your keycap fits that measurement you're golden. The slim version of the big ass enter key is noticeably different.
https://deskthority.net/wiki/Unit
https://deskthority.net/wiki/Return_key
Offline philberndt
« Reply #4 on: Sun, 15 May 2016, 17:28:06 »
I managed to contact the guy from the other thread (RabRhee) that had the spare caps, and he sold some to me, so problewm solved :D
thank you for your help.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sun, 15 May 2016, 17:33:09 »
I'm glad that you found the caps you need. Welcome
Offline LunarisDream
« Reply #6 on: Tue, 17 May 2016, 03:01:23 »
For future reference, you can find them on Taobao and Aliexpress, w/ the latter being easier to use but also marked up.
