Author Topic: Opening OEM switches  (Read 2859 times)
Offline heretyk
« on: Sun, 15 May 2016, 14:09:15 »
Is that possible to open factory-mounted MX switches without dismounting keyboard's case? I mean in situation when the bottom of the switch is behind the metal plate (KUL ES-87).
I'd like to lubricate my switches and I couldn't find information by searching older posts.
Offline xondat
  • i'm not a star
Re: Opening OEM switches
« Reply #1 on: Sun, 15 May 2016, 14:12:43 »
Probably not, I'm not familiar with the KUL.
Switches need to have the little openings in the plate, such as this:
You can't open plates like this:
« Last Edit: Sun, 15 May 2016, 14:14:53 by xondat »
Offline user 18
« Reply #2 on: Sun, 15 May 2016, 14:18:47 »
Just looked up pictures of the ES-87, and you cannot in fact open up the switches without desoldering.
Avatar by ashdenej
Offline heretyk
« Reply #3 on: Sun, 15 May 2016, 14:27:15 »
Thanks for replay. I feel disappointed there's no easy way to remove this scratchy feel when typing.
Offline klennkellon
  • I like bottoming out
« Reply #4 on: Sun, 15 May 2016, 14:36:22 »
welcome to Cherry where the tactility is made up and the smoothness doesn't matter
Offline xondat
  • i'm not a star
« Reply #5 on: Sun, 15 May 2016, 14:41:00 »
And this is why customs exist. The real question is will you pay for perfection :p
Offline HeeCh2ei
  • qdrw
« Reply #6 on: Sun, 15 May 2016, 14:48:46 »
You can desolder the switches and modify the plate.
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline heretyk
« Reply #7 on: Sun, 15 May 2016, 15:04:29 »
Probably not. I'm thinking rather of changing this keyboard to Realforce 87U but it's god damn expensive for me.
I didn't have any previous experiences with mechanical keyboards but now I know they don't met my expectations (esp. noise, scratchy feeling, wobbling keys).
Offline HeeCh2ei
  • qdrw
« Reply #8 on: Sun, 15 May 2016, 15:13:37 »
Let me guess, is it a browns on your keyboard?
Offline klennkellon
« Reply #9 on: Sun, 15 May 2016, 15:16:39 »
they will smooth out over time as you use them if that's any comfort for you, how long it takes is a combination of luck and how heavily you use the board.
Offline heretyk
« Reply #10 on: Sun, 15 May 2016, 15:20:31 »
Got browns. How did you know? :)
Offline HeeCh2ei
  • qdrw
« Reply #11 on: Sun, 15 May 2016, 16:00:41 »
Recently I sold keyboard on browns because topre. At first I don't have a plans to sell it, but in a direct comparison, browns shows all that "noise, scratchy feeling", which in reds are not present.
I also tried some different lubes on these switches. After lubing they become more linear and quiet. Linearity with a tactile bump is not ok, so I don't like the result.
Only spring lubing makes sense on the browns, I think.
« Last Edit: Mon, 16 May 2016, 07:25:11 by HeeCh2ei »
