Author Topic: Delete or backspace on HHKB?  (Read 7820 times)
Offline sandywind
« on: Mon, 16 May 2016, 07:22:22 »
How many of you have a HHKB have set it to output BS when Delete is pressed, maybe specifically to correct mistakes on the last typed word?
I have not, but I wonder whether it is more ergonomic to repeatedly type BS to correct a mistake, or type left arrow,  correct, then End, or even select the word backwards and type over, on editors that allow it, and disregard the question entirely.
Corsair Vengeance K65 w/ SP DCS Twilight Keycaps | Poker II w/ Danger Zone keycaps | HHKB Pro 2 | Realforce 87UW55 | IBM PC BS 80's | OLKB Planck | IC WhiteFox | Varmilo VA87ML
Offline davkol
  •  Post Editing Timeout
Re: Delete or backspace on HHKB?
« Reply #1 on: Mon, 16 May 2016, 08:17:43 »
This is more related to the original design of the HHKB. Old unix machines had a Delete key, instead of Backspace; see, for example, Sun Type 3.
If you used Emacs (as Eiichi Wada did), Ctrl-D would be delete and Ctrl-H backspace.
