Author Topic: Can all the extra keys on an IBM terminal keyboard be used as macros?  (Read 5869 times)
Offline QuincyJones
As much as I search, I seem to find conflicting answers, some saying no, whilst others, yes. So, as of today can the keys be used as macros with a decent converter? I'd imagine if they could, with another application like autokeys, it could make the keyboard quite powerful?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline y11971alex
  • Looking for Toronto meetup
Yes.
Offline QuincyJones
Thanks, does that include the M and the F?
(please like me)
M's can be programmed with a Soarer converter aka a Teensy and some wiring. Info can be found here. Fohat.digs also had a good thread on that. There's pre built ones as well. And I think phosphorglow has a converter out as well. I'm not sure if an SDL-USB cable will allow the computer to register all the scan codes properly so you can use like autokeys to program it.
F's use a converter. Mine's been converted with an xwhatsit converter. I believe there's another option called the DPH as well.
Offline QuincyJones
Thanks, it seems like terminal keyboards would be FAR more useful as a keyboard than a regular M! Other than the conversion process involved, are there any downsides to a terminal keyboard?
(please like me)
Downsides? It's a little more work to get them to work over PS/2 or USB. Like with an M, I could just get a PS/2 to USB converter. I forget if Fs come with PS/2 but I'm leaning towards. And you'll have to do a little work to get LEDs. Oh and they're huge. HUGEEEEEEEE. I don't like how big they are lol.
Offline khirin
  • Do more, with less.
Terminal model M and F can be converted with Soarer converter as mentioned earlier. For DIY project you may use the $5 pro micro instead of the Teensy.  Then, any single key macro should have no problem on both model M and F. However, The terminal Model M I have (M122) cannot register multiple keys, i.e. ctrl+alt+space dued to its 2kro while my F122 doesn't have that problem. Hope this help.
Offline QuincyJones
Oh wow, thanks for pointing that out. I didn't realise the terminal M is only 2KRO. That's... an issue for me! I wouldn't be able to do anything in Visual Studio!
Can 2KRO be changed via the USB controller, or would that be hardcoded on the actual keyboard controller?
(please like me)
Offline mike52787
  • Alps Aficionado
If you want to get around the 2kro, you have to buy a f122. all model ms internally only support 2kro because of the matrix printed on the membranes.  AFAIK there is no way to get above nkro with the model m. The model f on the other hand natively supports nkro.
Offline supamesican
If you get some copper foil, and solder some diodes to remake the matrix yourself it is possible to get nkro on an M. Wendel from teksyndicate did it, but he is also a wizard.
Re: Can all the extra keys on an IBM terminal keyboard be used as macros?
« Reply #10 on: Tue, 17 May 2016, 12:52:53 »
You know that "xKRO" numbers are only worst-case and that Control, Shift, and Alt don't usually count in that equation?
- Plato
Offline supamesican
« Reply #11 on: Tue, 17 May 2016, 19:46:48 »
Going to chime in as a professional developer that uses visual studio, I can confirm the 2kro on model M's causes no problems for me
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #12 on: Wed, 18 May 2016, 02:23:13 »
REALLY?! Oo that sounds incredible, do you have a link?
I'd still just go for an F btw, they're better anyway xD .
Offline supamesican
« Reply #13 on: Wed, 18 May 2016, 07:59:29 »
I'll see if I can find the video he talked about it in, he hasnt done a how to as of yet
Offline acid2000
« Reply #14 on: Wed, 18 May 2016, 10:00:00 »
2KRO is all good for me with VS.
With that in mind does anyone have a list of key combos that don't actually work?
