Author Topic: B.face X2 PCB  (Read 4131 times)
Offline cpeterson19
B.face X2 PCB
« on: Mon, 16 May 2016, 16:52:47 »
Is the B.face X2 PCB a good 60% pcb to use?
Thanks,
Re: B.face X2 PCB
« Reply #1 on: Mon, 16 May 2016, 16:55:33 »
Thanks,
No.
It's great.
Offline cpeterson19
Re: B.face X2 PCB
« Reply #2 on: Mon, 16 May 2016, 17:00:05 »
So what is the best 60% PCB?
Is it:
B.face X2
NerD 60
GH60
FaceW SPiRT Edition
Offline kiwi99
  • that's a gnarly dookie
Re: B.face X2 PCB
« Reply #3 on: Mon, 16 May 2016, 17:05:49 »
Is it:
B.face X2
NerD 60
GH60
FaceW SPiRT Edition
what are your needs? do you need rgb? is TMK a pro or a con to you? do you need in switch LEDs?  does price matter?
"best" is relevant to your needs.
Offline cpeterson19
Re: B.face X2 PCB
« Reply #4 on: Mon, 16 May 2016, 18:36:18 »
I don't need rub and sorry what's tkn? And price really isn't a factor and as far as LEDs I really just want like under glow!
Offline obviouslygene
Re: B.face X2 PCB
« Reply #5 on: Mon, 16 May 2016, 22:19:59 »
maybe read some pages.
like...
https://deskthority.net/wiki/Main_Page
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: B.face X2 PCB
« Reply #6 on: Tue, 17 May 2016, 21:16:04 »
If you really just want underglow I'd recommend the B. Face X2.
Very easy to reprogram & the LED's mounted on the bottom of the PCB are RGB so you can choose whatever color you want.
Offline FrostyToast
  • Litshoard
Re: B.face X2 PCB
« Reply #7 on: Tue, 17 May 2016, 21:19:25 »
You should probably give us an idea of what you're looking for in a keyboard.
No point in getting an expensive pcb if you wont even use any of the features. Perhaps, even, you'll buy a PCB that is good but doesn't have the features that another board would.
Quote from: elton5354
Offline DanielT
Re: B.face X2 PCB
« Reply #8 on: Wed, 18 May 2016, 12:10:12 »
Is it:
B.face X2
NerD 60
GH60
FaceW SPiRT Edition
1. NerD 60 - great piece of hardware and you can run TMK on it (you have also backlight and underlights)
2. GH60 (not the clones) - if you want a good board and don't care about lights. Runs TMK firmware
Also the other PCB's are good if you care only about fluff i.e. lights and stuff but they have issues and you are tied to closed source firmware, but I'm an old fart for me keyboards are tools not toys :))
