Author Topic: Greeting from Austin  (Read 4752 times)
Offline theXavier89
« on: Tue, 17 May 2016, 17:04:41 »
Hello all!
I'm a Clacker from Austin. I'm mainly on the Reddit under a different user name, but I've missed out on enough GBs that I have decided to get in on the GH as well.
Keyboard collection:
Das Model S Ultimate: Stock blues, thick blank black PBT caps
Das II: Stock. Gotta love the rebranded G80-3000 with blank POMs.
Leopold FC660M: Stock Blues. This one is a little rare, because I got it with Leopold black blank PBTs. I also have a HolyOOPs Arc Reactor esc.
Upcoming Project:
FC660M to Clueboard Conversion: I have a Clueboard PCB in transit as we speak, and I plan on using the original Leopold case and plate and just swapping out the PCB and switches. (I have some Zealios waiting to be put on the Clueboard) I'm also going to be clipping the stabs, and putting a white LED under the esc.
Before you ask, yes I name all of my keyboards.
       Betty                    Lucy            Elizabeth (Cluebard)
Re: Greeting from Austin
« Reply #1 on: Thu, 19 May 2016, 05:37:29 »
Welcome to Geekhack!
We won't hold Reddit against you :p
That's a nice collection - bit of a difference in size between the DAS and the FC660M!  I vaguely recall the hype when the DAS first came out with blank keycaps and thought it was so exotic.  Now keyboards like that are much more commonplace.
The project sounds interesting - a little bit of a few different mods and nothing too over the top - good luck with it :)
Offline theXavier89
« Reply #2 on: Mon, 23 May 2016, 17:22:31 »
So, I started desoldering the Leopold, and I learned desoldering is a lot harder than I thought. I originally wanted to salvage the PCB and the switches, but my first venture into desoldering showed that I wouldn't be able to do that.
Womp, womp.
But I'm going to finish the project soon and I'll be using my pretty new Clueboard in no time.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Mon, 23 May 2016, 17:33:26 »
Hey there, welcome. Yep, soldering is not always glamorous ;)
Offline theXavier89
« Reply #4 on: Mon, 23 May 2016, 17:54:48 »
Well, my understanding is that soldering itself is easy. It's desoldering that's a *****.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Mon, 23 May 2016, 18:09:28 »
Yea I guess when someone says "soldering" they're not encompassing all PCB type activities, my mistake. But not all soldering is easy and not all desoldering is difficult imo. Anyway, hope the Clueboard assembly goes smoothly. I would definitely read the build log should you decide to post one :)
Offline theXavier89
« Reply #6 on: Mon, 23 May 2016, 18:14:37 »
I have a few photos of my poor destroyed PCB as it is now, so I may do that.
Offline Suembeaux
« Reply #7 on: Mon, 23 May 2016, 20:20:45 »
Hello fellow Austinite!
I'm pretty sure I know who you are on Reddit, good to see you treading new waters. :thumb:
A bunch of stuff. Someone teach me how to properly solder.
/u/Shartastical
Offline theXavier89
« Reply #8 on: Mon, 23 May 2016, 21:18:30 »
Thanks! I'm trying it out.
PS: where do people get all of the signature images?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #9 on: Mon, 23 May 2016, 21:41:55 »
Keyboard pixel art things.
All about the pixelart :)
Offline Suembeaux
« Reply #10 on: Mon, 23 May 2016, 21:49:24 »
Yeah from here, I took others and edited them in photoshop to represent mine, but you could also do it in paint if you really wanted to.
/u/Shartastical
« Reply #11 on: Tue, 24 May 2016, 05:51:55 »
Correct.
There's dozens of threads here about desoldering - have a quick read and maybe someone has found a few tricks that might help.
Offline theXavier89
« Reply #12 on: Tue, 24 May 2016, 15:19:40 »
I've gotten tons of advice from my buddies at /r/mk. And my friends on skype. I may check out the stuff here just to get a little more.
« Reply #13 on: Wed, 25 May 2016, 05:45:19 »
And practice on old broken electronics devices too - nothing like a bit of practice :)
Offline Suembeaux
« Reply #14 on: Wed, 25 May 2016, 11:34:37 »
I have a broken BWU we can double team lol. I have been meaning to use it as practice but I just haven't had the time.
/u/Shartastical
Offline theXavier89
« Reply #15 on: Thu, 26 May 2016, 11:06:39 »
I used a motherboard from an oldass computer for soldering practice. It didn't do much for desoldering because the metal used for the solder on the motherboard had a much higher melting point than the solder used on keyboard switches.
Offline jceaser
    • My poor site
« Reply #16 on: Thu, 16 June 2016, 07:53:59 »
Hey, my home town, does the "Computer Goodwill" still have any good finds?
Offline Suembeaux
« Reply #17 on: Thu, 16 June 2016, 11:58:39 »
I have checked a couple times, all I ever find is unattended children and disappointment.
/u/Shartastical
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #18 on: Thu, 16 June 2016, 18:08:45 »
Offline theXavier89
« Reply #19 on: Fri, 17 June 2016, 22:40:12 »
I need to have at it.
