Author Topic: Filco replaceable cable mod  (Read 5910 times)
Offline kagey
« on: Tue, 17 May 2016, 21:59:37 »
I took about 3 hours to install a mini usb female adapter.
Used the female end of this:
To do a vertical placement, I had to:
- shave the inner shell down to nearly the bottom
- remove the softer plastic / rubber shell from the adapter
- sculpt the top corners down to fit into the rounded contour of the top shell
Cut the filco cable to reuse the pcb connector, and solder on the female adapter:
test placement:
Ironically solder the male end onto the filco cable to use as the first test cable:
the plate resting on the bottom shell, clearing the new parts, evidence of JB weld showing through:
everything buttoned up, no real ugly evidence of case modification:
sweet curly cable bro:
now to get a pimp cable!
Offline TalkingTree
    • My projects
Re: Filco replaceable cable mod
« Reply #1 on: Wed, 18 May 2016, 03:53:25 »
I did the same thing a while ago but your results look definitely cleaner than mine.
(click to enlarge)
Offline kagey
« Reply #2 on: Wed, 18 May 2016, 09:24:19 »
Thanks for the compliment! This is my first keyboard hardware mod but I've done some work on modding game consoles before. Cheers,
Offline yomammary
« Reply #3 on: Wed, 18 May 2016, 09:39:09 »
Good job!
RF 87u 55g | Leeku 1800
Offline TalkingTree
    • My projects
« Reply #4 on: Wed, 18 May 2016, 14:32:41 »
I'd happily see them.
Offline kagey
« Reply #5 on: Thu, 19 May 2016, 18:31:05 »
Sure, this is the only one I still have in my possession. It's a version 1 gameboy advance with:
- aftermarket case
- a backlit led screen from an advanced sp v2
- glass screen cover
Offline SKD
« Reply #6 on: Fri, 20 May 2016, 05:33:10 »
- aftermarket case
Sweet! I like that. I also have one in silver to mod but not sure if I'll actually play it afterwards. I just sold my Gameboy Advance Micro, 3DS XL, PSP Phat and PSP Go cos I don't play  handhelds anymore.
Offline TalkingTree
    • My projects
« Reply #7 on: Fri, 20 May 2016, 06:56:57 »
- aftermarket case
Nice indeed. You know your way around.
Offline kagey
« Reply #8 on: Fri, 20 May 2016, 08:38:28 »
- aftermarket case
I don't use it much either, but I have 4 gbas and the link cables and every now and then it's fun to bust out 4 way Mario kart when the gang is over.
Offline kagey
« Reply #9 on: Fri, 03 June 2016, 22:27:42 »
Execution #2. Repeatable method? Scientific method? I'm a scientist? yay for science?
