Author Topic: Leds and clue board [solved]  (Read 1689 times)
Offline Gmac
« on: Fri, 20 May 2016, 08:30:40 »
Hello makers of stuff! I am knew to keyboards and this type of in depth stuff. I recently purchased a clueboard. So it has led capability for its caps lock and escape, as well as a RGB points on the bottom, but I'm not exactly sure what I'm doing. So I know that i need the leds, and diodes and the solder them, but I only have an inkling on how to do that. if i could get some help that would be much appreciated.
EDIT: The only decent site I have used to order parts like this from is adafruit, if there is another(or better in your opinion) to order these from please let me know?!
« Last Edit: Sat, 21 May 2016, 08:49:11 by Gmac »
Offline Gmac
Re: Leds and clue board [solved]
« Reply #1 on: Sat, 21 May 2016, 08:49:57 »
Thank you for all the views but I found out what I needed to do!  I'll share my board when it's done! Happy making!
