Author Topic: Custom keyboard with a custom plate  (Read 3275 times)
Offline Macpants
« on: Sun, 22 May 2016, 17:40:12 »
Hey everyone! I had the idea of building my own keyboard from scratch and I've started by ordering some parts starting with the following:
  • Phantom PCB (TKL)
  • Teensy 2.0 controller
  • Gateron Browns
    • (if you looked at my intro and first posts I mentioned these as well. I appreciate all the replies and I nearly did go for another set. Using my judgement of my own preferences, I got to a conclusion)
  • Keycaps TBD
  • Custom faceplate/case
That last one is the one I'm really wondering about. I have a plan to take a piece of sheet aluminum and cnc the switch holes out (I do have access to a CNC router, the ShapeOko). The only thing I can't figure out is how thick a sheet (or a plate, maybe?) of aluminum I should get. In terms of grade/type of aluminum, my research is pointing to 6061-T6 due to it's apparent ease of machining and welding. Anyone fabbed their own faceplate out of aluminum before? Care to help a fellow mechie out? :)) ...I'm a nerd.
Thanks, all!
Offline joey
Re: Custom keyboard with a custom plate
« Reply #1 on: Sun, 22 May 2016, 17:41:51 »
1.5mm is the standard thickness.
You can use a thicker plate, and only have 1.5mm in the parts that the MX switches clip onto. That requires a lot more work than just using a 1.5mm plate though!
Offline Macpants
« Reply #2 on: Sun, 22 May 2016, 17:58:37 »
Well sweet, that was fast! Thanks!
I don't have the parts in hand, so I'm basically just working from my imagination at the moment. Please pardon any seemingly obvious questions I'm asking here... What would happen if the plate was slightly thicker, say 1.6mm? Could the PCB just be put ever so slightly closer to the plate?
« Reply #3 on: Sun, 22 May 2016, 19:22:12 »
If you use a too thick plate the switches won't clip on to it, that's not a problem if you're using a PCB though as they aren't going to pull out anyway :)
Offline Macpants
« Reply #4 on: Sun, 22 May 2016, 21:12:56 »
Ahhh ok. That makes sense. I've done some searching and everything I've found is in inches. :mad: Unless I buy it from England or something, which seems a bit excessive considering I live in the USA. Urg. Anyone know of a metal place that trades goods in 'Murican dollars AND measures in mm?
Offline tacnificent
« Reply #5 on: Sun, 22 May 2016, 22:37:45 »
You can order sheets on amazon if you can't find something locally.
http://www.amazon.com/Aluminum-Unpolished-Finish-Standard-Tolerance/dp/B00CNLV9B8
0.05" (~1.3mm) or 0.063" (~1.6mm)
