Author Topic: WYSE NIB terminal keyboard ( Vintage black)  (Read 6980 times)
Offline Jin
Offline JeremyFXDWG
Re: WYSE NIB terminal keyboard ( Vintage black)
« Reply #1 on: Sat, 04 June 2016, 23:40:33 »
Would you mind posting the manufacture date of the board? Are they definitely vintage blacks?
Thanks
Jeremy
Offline Nafs_asp
« Reply #2 on: Sun, 19 June 2016, 19:44:35 »
http://www.ebay.com/itm/Vintage-Wyse-French-ANSI-Keyboard-20-Function-Key-Cherry-Key-Switches-900243-47-/131817097627?hash=item1eb0e9499b:g:spcAAOSwAuNW8acl
Switches are really nice , i bought this when i upload here  :thumb:
Did you end up getting this board? Could you confirm if the switches are vintage MX blacks?
Offline orihalcon
« Reply #3 on: Sun, 19 June 2016, 20:50:42 »
The seller has some other boards from the same batch with slightly different caps, and there is a closeup picture on that one:
140174-0
http://www.ebay.com/itm/131827152470
Appears to be a mix of different types of blacks which is not uncommon for Wyse boards apparently.
Offline Nafs_asp
« Reply #4 on: Sun, 19 June 2016, 20:54:49 »
Yup, I've been watching those (and several other boards the seller has. Any idea what the distribution of vintage to non-vintage blacks is? I'm trying to source enough for a 60% build (so 61 + some spares)
Offline Jin
« Reply #5 on: Sun, 19 June 2016, 21:48:14 »
its vintage black i got one and use for build , its very smooth  :thumb:
