Author Topic: Captcha  (Read 11342 times)
Offline TheVengeance
Captcha
« on: Tue, 24 May 2016, 06:26:29 »
Honestly, I really find posting here quite annoying.
The user experience on mobile is bad enough but the quality of the captcha image is always so bad it takes multiple attempts every time.
Can we not use recapture or something a bit more forgiving?
Re: Captcha
« Reply #1 on: Tue, 24 May 2016, 06:29:47 »
Keep posting it'll go away soon enough.
Offline zcmy
  • I really should be working... not "working"
Re: Captcha
« Reply #2 on: Tue, 24 May 2016, 07:12:28 »
Went away for me at 10 posts. Just keep posting good content and you should be a-ok. :D
Re: Captcha
« Reply #3 on: Tue, 24 May 2016, 21:42:55 »
I wonder if it is 10 posts that count, or 10 posts overall (given that posting in some areas of the forum don't affect your post count)?
Re: Captcha
« Reply #4 on: Tue, 24 May 2016, 21:54:00 »
**** post to 10.
blame artisan groupies for the stupid rule.
Offline user 18
Re: Captcha
« Reply #5 on: Tue, 24 May 2016, 22:07:23 »
I'm not sure. My guess is that it would be tied to post count, rather than number of posts.
In any case, it goes away fairly quickly. Are you posting on mobile using your device's browser, or the Tapatalk app?
Avatar by ashdenej
Offline kingpilcrow
Re: Captcha
« Reply #6 on: Wed, 15 June 2016, 10:35:30 »
HFTDBW
USB
Offline mrhead
  • Thread \ (•◡•) / Stopper
Re: Captcha
« Reply #7 on: Wed, 15 June 2016, 12:36:26 »
I was beginning to wonder if the captcha went away after a while as well.  Having a red-green color deficiency doesn't help deciphering the letters.
Re: Captcha
« Reply #8 on: Wed, 15 June 2016, 21:43:12 »
Yes, you just need to post a little more :p
Offline mrhead
Re: Captcha
« Reply #9 on: Thu, 16 June 2016, 12:10:27 »
Ironically, after that post, the captcha prompts went away.
Re: Captcha
« Reply #10 on: Thu, 16 June 2016, 21:41:57 »
At or after 10 posts, it seems.
Re: Captcha
« Reply #11 on: Sat, 18 June 2016, 11:20:49 »
That's not really ironic
