Author Topic: Rantopad MXX Red Case Gateron Black  (Read 3160 times)
Offline Myk!
« on: Fri, 27 May 2016, 07:03:58 »
Rantopad MXX Red Case Gateron Black Switch
http://imgur.com/a/k4q2z
Aluminum plate painted with red glossy car paint
Macro On-the-fly
White backlight
Floating keycaps
6 Light Modes (Custom, reactive, breathing, ripple, wave, trace)
5 brightness level (including off)
Custom per key backlighting
Removable braided USB Type A cable
Standard layout keycaps
Keypuller
Full NKRO (tested)
Media Keys
Calculator and Explorer Shortcut
Gaming Mode
(Actual)
Keyboard weight - 680 grams
Dimension - 380mm x 125mm
Height at back 28mm (surface to plate)
Height at front 14mm (surface to plate)
Cable 4.5mm thick
And our custom backlit keycap. MKWPH stands for Mechanical Keyboard Warriors Philippines
« Last Edit: Sat, 15 April 2017, 20:21:45 by Myk! »
