Author Topic: Keyboard feet  (Read 2869 times)
Offline Perfex
Keyboard feet
« on: Fri, 27 May 2016, 14:06:39 »
I had an issue with the feet on my FMJ poker case, so I went on a hunt for some material that was appropriate for the application... took a while but I found some.
Just figured I would share the info for anyone else on the hunt... fyi it's similar to the material on the standard poker case
http://www.ebay.com/itm/Non-Slip-Rubber-Pad-with-strong-self-adhesive-backing-100mmX50mmX2mm-Thick-2PCS/221310033971?_trksid=p3693.c100102.m2452&_trkparms=ao%3D1%26asc%3D20140212121249%26meid%3D3b935bba6ba64c60b149cfc9dd28cecc%26pid%3D100102%26
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Keyboard feet
« Reply #1 on: Fri, 27 May 2016, 17:39:26 »
Thanks for sharing. Looks like these pads would secure a keyboard better than the aftermarket laptop bumpons I have bookmarked
