Author Topic: GH60 Rev.C Underglow with a WS2812 strip  (Read 20212 times)
Offline robotmaxtron
« on: Fri, 27 May 2016, 14:42:40 »
I've been trying to read up on some the specifics of the GH60 pcb (Not the Satan board, the Rev.C) and I saw on the QMK Github readme that it's possible to use a strip of the leds as an underglow type effect with the KC60. Am I understanding things correctly that there are some in-switch led support for things like the WASD and PokerX clusters, this could be leveraged to control an rgb strip of WS2812 leds on the GH60 Rev.C?
I'm trying to get things in order for a full parts list, switches and keycaps are the obvious bits but before I decided on a case I wanted to verify the possibility of the underglow type lighting option.
Offline komar007
    • komar's blog
Re: GH60 Rev.C Underglow with a WS2812 strip
« Reply #1 on: Fri, 27 May 2016, 14:48:30 »
robotmaxtron,
If you build simple transistor based switches for the strip, you can either use 3 of the 4 LED pins (which are also available as pads on the board labelled as GPIO), or if you don't want to use 3 of those, there is also 1 unused pin, PB0, but that would require soldering directly to the chip's pin.
« Reply #2 on: Fri, 27 May 2016, 16:45:34 »
robotmaxtron,
I found these images which I think is from the GH60 Satan PCB, but is this what you mean?
Overview
Closeup of soldered to PB0
Glamour shot/results
Would that be all that it would take? Just wiring to PB0 and then supplying power and ground?
Additional shot of where PB0 is:
Offline odd
« Reply #3 on: Fri, 27 May 2016, 23:19:59 »
robotmaxtron,
Overview
That's not PB0 in the pics BTW so don't go messing up your board  :p
Offline komar007
    • komar's blog
« Reply #4 on: Sat, 28 May 2016, 02:41:19 »
robotmaxtron,
Overview
Sorry, I didn't read what WS2812 is, so in fact you need just one pin and forget about the transistors.
As mentioned, it's not PB0 in the picture, but the general idea is right. If you don't need all 4 LED clusters, then go ahead and use one of GPIO pins instead of soldering directly to the chip.
« Reply #5 on: Sat, 28 May 2016, 12:28:48 »
Very cool. Thanks for your input. I'll of course post some pictures and everything as progress happens.
« Reply #6 on: Thu, 09 June 2016, 22:07:29 »
I'm working on my QMK keymap while I wait for the last of my parts to arrive, I was hoping somebody could help take a look at my keymap to see if I'm on the right track. There's a couple things that I'm not sure I understand.
Is this how this is supposed to work to both work as a capslock and a momentary switch to a function layer named _FL?
Code: [Select]
ACTION_LAYER_TAP_KEY(_FL, KC_CAPS),
How do I enable the caps lock when it's toggled?
Code: [Select]
gh60_caps_led_on()
I don't understand this section:
Code: [Select]
const macro_t *action_get_macro(keyrecord_t *record, uint8_t id, uint8_t opt)
  // MACRODOWN only works in this function
      switch(id) {
        case 0:
          if (record->event.pressed) {
            register_code(KC_RSFT);
          } else {
            unregister_code(KC_RSFT);
        break;
    return MACRO_NONE;
Full Keymap: https://github.com/robotmaxtron/GH60-Rev.C-Keymap/blob/master/max.c
Edit: Removed old repo, full repo is available in the next reply.
« Last Edit: Sat, 11 June 2016, 22:03:31 by robotmaxtron »
« Reply #7 on: Sat, 11 June 2016, 22:01:17 »
Well the good news is that my keymap compiled at least.
Full source is available here: https://github.com/robotmaxtron/qmk_firmware/tree/master/keyboard/gh60/keymaps/robotmaxtron
I haven't tested it yet since I'm still waiting on switches. Stabs installed, switches ordered, the plate and pcb are here. Progress is coming along!
« Reply #8 on: Sun, 03 July 2016, 11:03:25 »
Mostly finished with the board, the neopixel strip half works. I can get it to turn on/off and change mode but I haven't been able to get it to change colors.
Full build log posted here: http://imgur.com/gallery/tlm0C
Offline cyd3r
« Reply #9 on: Wed, 06 July 2016, 17:17:34 »
Looking at this just confuses me even more. I've got the KC60 (purple PCB '2015-09-12 Version 2.0') as shown here https://imgur.com/a/kYyyb
How exactly could I use the strip LEDs for underglow while using the LEDs on the switch at the same time (Is this even possible? If so how?)
« Reply #10 on: Thu, 07 July 2016, 16:29:44 »
Here's some pretty clear instructions on wiring and everything with the KC60 v2.0: https://github.com/jackhumbert/qmk_firmware/tree/master/keyboards/kc60/keymaps/ws2812
Offline Moistgun
  • Slippery When Wet
« Reply #11 on: Thu, 07 July 2016, 16:43:32 »
Theres a thread on this on DT.
https://deskthority.net/workshop-f7/gh60-rev-c-underglow-with-a-rgb-strip-questions-about-the-pcb-pinout-t13897.html
Its not a complete clear explanation, but its a start.
« Reply #12 on: Fri, 08 July 2016, 11:33:21 »
I got the neopixel strip working on the GH60 Rev.C after adjusting some of my keymapping.
http://i.imgur.com/sxGmxC5.jpg
Offline redbanshee
  • actually Dade Murphy
« Reply #13 on: Fri, 08 July 2016, 12:22:56 »
Well done! Care to share your git repo? looked thru your repo's and see the GH60 one but it doenst appear to have the QMK code in there
EDIT: nevermind
« Last Edit: Fri, 08 July 2016, 13:47:09 by redbanshee »
Offline cyd3r
« Reply #14 on: Fri, 08 July 2016, 13:27:39 »
I'm new and not so good when it comes to modding and DIY stuff. It would be awesome if someone could explain this or put it to steps. Like where is the "unused pin B0", "PF5 breakout pin", "VCC", "GND", and "DI".
Which part needs soldering? Is it the same for KC60?
Do you solder the wires any different from the switches?
I just found about 2016-04-19-Satan-GH60-Build-Log by cheddarbek and have a vague idea now.
*edit
Found http://imgur.com/a/NxL1X by fuzzycuffs.
Also I don't know why but anything related to "a0-c" is gone. By that I mean his reddit account deleted github repository removed, his imgur album deleted
All my answers were here though it's useless now, since it's not available anymore.
« Last Edit: Fri, 08 July 2016, 13:55:37 by cyd3r »
Offline Moistgun
  • Slippery When Wet
« Reply #15 on: Fri, 08 July 2016, 15:47:43 »
*edit
Are you trying to do this to a GH60 PCB or a Satan PCB?? very different things.
I can help you with the latter.
Offline cyd3r
« Reply #16 on: Fri, 08 July 2016, 16:30:32 »
It's actually KC60. I'm assuming it's the same as GH60, someone got it working here https://geekhack.org/index.php?topic=82762.0
Offline Moistgun
  • Slippery When Wet
« Reply #17 on: Fri, 08 July 2016, 18:01:12 »
I suggest you post in that thread or pm the guy.
They arent going to be the same.  Maybe minor differences, but not the same.
« Reply #18 on: Sat, 09 July 2016, 00:46:59 »
EDIT: nevermind
I've been neglecting my QMK repo, but yes I absolutely plan to submit a PR actually upstream to the QMK core so that others can use mine as an example. There was a recent change to how the config to the WS2812 strip actually works with QMK that I still haven't sorted out yet.
« Reply #19 on: Sat, 09 July 2016, 00:48:42 »
Again, as I mentioned in Reply #10 there are very clear instructions on how to wire the KC60 and how to program it in the QMK repo.
« Reply #20 on: Sun, 10 July 2016, 00:52:20 »
Keymap has been accepted upstream to QMK: https://github.com/jackhumbert/qmk_firmware/pull/502
« Reply #21 on: Thu, 14 July 2016, 15:36:20 »
Forgot to post the updated build log: http://imgur.com/a/NkwCD
« Last Edit: Thu, 14 July 2016, 15:38:54 by robotmaxtron »
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #22 on: Fri, 15 July 2016, 11:52:38 »
It worked beautifully.
I killed a few LEDs at first by not insulating the back of the strip - they shorted out against some pads on the PCB and left the whole strip non-operational.
I stuck some electricians tape over the pads on the back, cut off 8 LEDs, spaced them around the edge of the PCB and used some 26 gauge hookup wire to join them all up.
Thanks for putting in the footwork to get this working.
Offline Moistgun
  • Slippery When Wet
« Reply #23 on: Fri, 15 July 2016, 12:32:29 »
I did the same thing,  shorted some lights and had to start over
« Reply #24 on: Fri, 15 July 2016, 13:41:15 »
I've got you both beat. I shorted out my pcb, the reason the wiring look a million times better in this build log is because I had already done it once.
Offline MajorKoos
« Reply #25 on: Fri, 15 July 2016, 16:35:09 »
You "Win".  I guess you got "Lucky" and fed 5v into the microcontroller.
On the bright side you now have a donor board to cut in half and make a split ergo 60% with a RGB backlight.
