Author Topic: Hi - New Member here  (Read 2684 times)
Offline andrzejski
« on: Fri, 27 May 2016, 17:13:30 »
Hey guys, new-ish member to mech scene. I had a corsair strafe that I inherited for a while and recently bought a pok3r of my own after being on the fence between a pok3r and FC660m for a long time. I wish I could use blues all the time, but browns work pretty well for me too. I tried stock MX clears and couldn't stand the heat...
I guess that's me!
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: Hi - New Member here
« Reply #1 on: Fri, 27 May 2016, 21:20:10 »
Welcome :)
What do you mean by not being able to stand the heat of Clears? :p
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Fri, 27 May 2016, 21:43:29 »
Gosh, everyone knows that Cherry MX clear is that fire :cool:
Welcome aboard. I have this sneaking suspicion that you're looking for a new keyboard. Perhaps a new switch?
Offline khirin
  • Do more, with less.
« Reply #3 on: Sat, 28 May 2016, 20:23:40 »
At first I thought Cheery MX Clear switches are very heavy. But after spent some weeks with Model M, they are not that stiff at all.
« Reply #4 on: Sun, 29 May 2016, 01:10:21 »
Welcome to Geekhack!
Not too much between the Pok3r and the FC660M, apart from the arrow keys on the FC660M.
I like MX clears - they are about the only switch I don't bottom out on all the time.  I also prefer stiffer switches generally - I guess it's just a matter of how strong the fingers are and/or how hard you type.
Any plans for another keyboard?  Something Topre perhaps?
Offline fancymans
« Reply #5 on: Wed, 01 June 2016, 10:35:53 »
You should try out some MX Ergo Clears. ;)
Realforce 87U 55g 10th Silenced | HHKB Silenced | FC660C
