Author Topic: DIY Keyboard  (Read 3327 times)
Offline Dr.Chipotle
DIY Keyboard
« on: Fri, 27 May 2016, 22:19:42 »
So I was wondering, what some good keyboard kits to buy? I'd like to build a mechanical keyboard along with leds and was wondering who could point me out in the right direction.
Offline Data
Re: DIY Keyboard
« Reply #1 on: Sun, 29 May 2016, 10:40:35 »
You didn't give us a lot of information here so I'm going to assume this is your first build and that you know your way around a soldering iron.
I'd start with this kit: https://www.massdrop.com/buy/sentraq-60-diy-keyboard-kit?mode=guest_open
No LEDs but a respectable number of options for customization and it has literally everything you'll need including the USB cable -- at a fantastic price.  Make sure you read through ALL the comments before you commit to buy so you can see what others are saying about the board.  Good luck!   :cool:
Offline Dr.Chipotle
Re: DIY Keyboard
« Reply #2 on: Sun, 29 May 2016, 18:04:29 »
Ye this is going to be my first build, do you know of any tkl kits? that board is kinda too small for me.
Offline tacnificent
Re: DIY Keyboard
« Reply #3 on: Sun, 29 May 2016, 23:42:17 »
B.87 from winkeyless and NerD TKL from GON if you want to splurge.
Otherwise, there's a TKL kit on aliex. Just search Keycool DIY. You'll need to supply your own switches, LEDs and keycaps
Offline Dr.Chipotle
Re: DIY Keyboard
« Reply #4 on: Mon, 30 May 2016, 12:56:52 »
hmm i don't see an 87 kit, however i did see a 104
