Author Topic: Replacement Plate full size like "Phantom"  (Read 3440 times)
Offline Shihatsu
« on: Sat, 28 May 2016, 03:10:53 »
Hi guys, I want to mod my Filco Full Size ISO to be able to open switches without desoldering the switches. So I am looking for a replacement plate in phantom style. Can you recommend one? O, and hi gh.
Offline xondat
  • i'm not a star
Re: Replacement Plate full size like "Phantom"
« Reply #1 on: Sat, 28 May 2016, 05:45:09 »
Don't think there are any that are readily available but you can create your own and have it made if that interests you.
« Reply #2 on: Sat, 28 May 2016, 08:38:51 »
Welcome to gh :)
If not a fullsize perhaps you could use a phantom and a separate tenkey plate? Depends how it's hel together..
Offline Shihatsu
« Reply #3 on: Mon, 30 May 2016, 11:28:44 »
Huom, there isn't a full size plate available. Designing one by myself.... where to start? Never did anything similar? Any help or suggestions would be appreciated.
« Reply #4 on: Mon, 30 May 2016, 11:37:14 »
The easiest way is to go to www.keyboard-layout-editor.com and create the layout, then use can use swill's website (see this thread) to convert it to a CAD file to get cut :thumb:
« Last Edit: Mon, 30 May 2016, 11:39:12 by suicidal_orange »
Offline Charger
« Reply #5 on: Mon, 30 May 2016, 11:55:14 »
probably best to check the measurements when doing that I seem to recall it not just defaulting to the phantoms spacing
Offline Data
« Reply #6 on: Mon, 30 May 2016, 20:35:58 »
Correct. You'd need to adjust the spacing of the nav cluster in CAD. Probably the numpad too.  Basically just measure carefully before you have anything cut.
Offline n__dles
« Reply #7 on: Wed, 24 August 2016, 10:48:26 »
« Reply #8 on: Wed, 24 August 2016, 10:56:45 »
This (https://geekhack.org/index.php?topic=56007.0) will probably be available to order soon.
« Reply #9 on: Wed, 24 August 2016, 10:58:00 »
« Reply #10 on: Wed, 24 August 2016, 11:16:21 »
Please express interest here, so they will know there are potential buyers waiting. :)
