Author Topic: I need a GOOD Ergonomic Keyboard  (Read 19294 times)
Offline CaptainKirk
« on: Thu, 24 December 2009, 09:10:24 »
I had a nice thread here a month and decided to buy a Kinesis Freestyle to replace my old Datadesk. The feel of the keys on the Kinesis is very nice and the overall layout is nice, BUT there are two serious problems which I feel are mistakes. To repeat them, they are:
1 the layout of the ZXCVB keys is more like a traditional keyboard and
not like an ergonomic one. What I mean is that the B key is down and
to the right of the G key whereas in an ergo keyboard, like my
Datadesk, the B is below and slightly to the left of the G.
If I put my hands on the home position and close my eyes and let my
fingers naturally curl in towards the palm, the right fingers land on
the correct keys, but the left hand lands a half key off. This seems
to be a real pity. On my Datadesk the top left corner of the B is
adjacent to the bottom right corner of the F. In this Kinesis, those
two corners are about a half inch away from each other.
2 a touch typist types a 6 with this right hand. This keyboard puts
the 6 on the LEFT keyboard. It's bizarre and I believe it's a mistake.
But now what should I do? The Datadesk now feels so HARD to press the keys, but the ZXCVB are perfect, as is the 6.
I suppose I could get uTRON or the fancy fancy keyboard from Kinesis or Maltron. Even the cheaper one at Kinesis, however, is 3 times the keyboard I am trying to return.
Any advice for a guy who just wants a good ergo keyboard?
Offline JBert
« Reply #1 on: Thu, 24 December 2009, 11:25:34 »
This problem is hard to solve as most keyboard makers do what they feel is right. I see a few options, although not all as realistic:
  • Make a custom Cherry keyboard. At least one member posted how he made the switch-holding plate and the matrix. Only for advanced DIY geeks.
  • Buy another SmartBoard and mod the Alps switches. This is still a lot of work though, takes some skill and might result in a keyboard with varying weights. It mostly takes time.
  • Buy a Kinesis Contour keyboard, possibly second-hand. This isn't an adjustable split keyboard though.
  • Buy some other keyboard and try to live with it. Takes no DIY stuff, only retraining of your muscle memory.
Other than that, I think you are out of luck unless someone else has any ideas.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline Rajagra
« Reply #2 on: Thu, 24 December 2009, 11:29:02 »
I don't know a perfect ergonomic keyboard, but I'm going to point out a problem with what you are asking for.
On the one hand (no pun...) you are asking for a keyboard that is brave enough to depart from the conventional layout. But on the other hand you are complaining that the 6 key should still be assigned to the right hand. You can't have it both ways - do you want conventional, or do you want improved?
This is why the perfect ergonomic keyboard doesn't exist. Nobody will ever agree on the best layout.
I too have posted that 6 "belongs" to the right hand. But people pointed out that the 6 key is closer to the left index finger than the right one. And they were right when I checked. The B key is equidistant. The ideal for split keyboards would be to have B and 6 duplicated on both sides to suit all users.
I have to agree with the problem with how the keys are staggered. Even if you retrain your typing as per the picture below it isn't ideal, because you would be increasing how far you have to reach for the QWERTY row - 3/4 key width instead of 1/4 key width.
Offline CaptainKirk
« Reply #3 on: Thu, 24 December 2009, 12:29:52 »
@JBerg: I am not a DIYer, unfortunately.
I actually don't have that much interest in a split keyboard. I am happy with an ergo one-piece. I got the Freestyle just because it seemed the best choice, that's all.
Quote from: Rajagra;145056
The 6 is closer to the left index finger only a keyboard that puts it there. On my Datadesk it's way closer to the right. :)
I found some great up-close pictures of it here: http://www.atpm.com/12.05/smartboard.shtml
But the drawbacks are also serious: odd placement of home/end/pgup/pgdown and hard-to-press keys.
So perhaps a Kinesis Contour or Advantage will be an idea. Only problem is that I am in Israel. Someone brought me the Freestyle from the USA (and could return it) but to ship a new keyboard makes it even more expensive. And to purchase in England appears to be the same. OK, maybe that's just life. :)
Thank you.
Offline Rajagra
« Reply #4 on: Thu, 24 December 2009, 18:53:57 »
The main layout of that smartboard is pretty good, apart from the navigation keys, as you say.
While looking for better pictures, I stumbled across the Truly Ergonomic Computer Keyboard:
Based on Cherry switches (brown, blue or black) and planned to be available Q2 2010. I quite like it.
Edit> They have a survey linked at the bottom of that page, so if you think it needs improvement, now is your chance to let them know! :smile:
« Last Edit: Thu, 24 December 2009, 19:03:40 by Rajagra »
Offline CaptainKirk
« Reply #5 on: Fri, 25 December 2009, 03:48:49 »
I have only one thing to say regarding your post:
GET ME ONE. NOW!
I took the survey also. ;)
Fantastic find, mate. Keep up the good work! :)
Offline dusanx
« Reply #6 on: Fri, 25 December 2009, 05:29:59 »
Quote from: Rajagra;145130
Very interesting layout, looks like I can use it. They have Qwerty and Dvorak in that survey but there is no mention of Colemak. I suggested truly exchangable keycaps or Colemak layout out of the box. Can't beat small layout and this may be first 'ergonomic' kbd that I like.
Offline Rajagra
« Reply #7 on: Fri, 25 December 2009, 14:11:09 »
I mentioned Colemak and split/adjustable designs when I filled the survey. Interesting to note that in the survey they already hinted at layouts that are better than Dvorak - could this be the first Colemak in hardware board? I'll post in the Colemak forum, see if we can make this happen.
Offline rdjack21
« Reply #8 on: Fri, 25 December 2009, 21:45:16 »
That is a pretty interesting keyboard like it is but it really needs to be programmable because I don't really like some of the choices they have made for the keys in the middle and the sides. Really dislike the position of the tab key and Esc being moved to the top. I think it would have been better to move the backspace to the middle and move the -= keys back to where they belong. But still an interesting board. Might even get one after I get the μTRON if the build quality is there.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
« Reply #9 on: Sat, 27 February 2010, 02:30:17 »
Looks a lot like this:
http://www.dansdata.com/edkb.htm
Offline itlnstln
« Reply #10 on: Mon, 01 March 2010, 07:46:18 »
Quote from: Whiskey in the Jar-o;161096
Where have you been?  Are you still using nekkid ALPS?
« Reply #11 on: Mon, 01 March 2010, 19:05:08 »
Quote from: itlnstln;161341
The Evolution is gathering dust for now, until I can work out better keycaps (hate the wobble).  Nekkid is just too prickly.  These days, I mainly use MS Natural boards: Multimedia at work, NEK4000 and the original Natural at home.  I also have a solar-rechargeable Cherry Cymotion, but the batteries kept getting drained.   This forum sure has grown since the early days (and I thought I was the only one).  But as my RSI subsided, so did my KB obsession.
Offline TexasFlood
« Reply #12 on: Mon, 01 March 2010, 19:47:17 »
Looks pretty sweet.  Wish it had a trackpoint.
Offline iMav
  • geekhack creator/founder
« Reply #13 on: Sun, 05 December 2010, 20:40:20 »
Quote from: Whiskey in the Jar-o;161393
Huh.  Going through some old threads and realized i had totally missed a brief return from one of our EARLY members.
Don't be a stranger!!  ;)
Offline taswyn
« Reply #14 on: Mon, 06 December 2010, 04:17:15 »
Since you already ressurected it, I can't resist
Does anybody ever build physical prototypes any more?
Of course they do... when they actually intend to at least TRY releasing a product =P yay vaporware!
Also that would have been the perfect keyboard, except I *hate* with a passion the diamond arrow key configuration. Yay pyramid! It reminds me of the MS Ergo Elite vs Pro, and how sad I was that it was the Pro that was discontinued =/ That and they messed around with the ctrl/shift/alt placement far too much for me, in the "latest" mockups on their site >.>
Offline bluecar5556
« Reply #15 on: Wed, 09 March 2011, 15:22:51 »
Split Kinesis Contour Classic (advantage) keyboard mod
Offline YoshiCaps
  • yes, oh god no.
Re: I need a GOOD Ergonomic Keyboard
« Reply #16 on: Sat, 22 October 2016, 21:32:37 »
Dude, are there ergonomic mechanical gaming keyboards  :))
hi.
Offline profet
« Reply #17 on: Sun, 23 October 2016, 16:02:07 »
Holy thread necromancy
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #18 on: Sun, 23 October 2016, 16:20:15 »
Awesome thread but damn that necro, though
Offline vvp
« Reply #19 on: Sun, 23 October 2016, 16:58:17 »
I would say Kinesis Advantage is qute a good gaming keyboard. It has on the fly remap/macros which may be usefull for games. But does not have profiles/configurations and cannot send mouse events.
Does King's assembly count as gaming?
https://bestmoschino.wordpress.com/2016/04/06/three-body-keyboard-easily-surpass-30-years-on-hand-speed/
I build my own version of split kinesis/maltron. Not sure it counts as gaming. I have programmed a strafe jump macro in it (it can run simple C-like programs like macros; the programs can be loaded into keyboard with a PC app). But it does not have back-light. If that is what you mean by gaming.
https://deskthority.net/post282413.html#p282413
And that thread points to a few other DIY contoured keyboards.
 Is there any ergonomic keyboard with back-light? Looks like this one has back-light:
http://designtaxi.com/news/376865/This-Butterfly-Shaped-Wooden-Keyboard-Is-Ergonomic-And-Fully-Customizable/
This adjustable topre board looks interesting too.
https://deskthority.net/workshop-f7/designing-a-custom-topre-board-t11734.html
« Reply #20 on: Wed, 16 November 2016, 11:46:47 »
The Kinesis Advantage has been discontinued, replaced with Kinesis Advantage2. This one has an updated controller which does have support for multiple configurations that you could change between with a key combination. (I have not read the user manual, so don't ask me for details).
Kinesis has also talked now and then that they are going to make a mechanical gaming version of the Freestyle2.
No details are out on when it will be available though.
Offline vvp
« Reply #21 on: Wed, 16 November 2016, 12:23:28 »
Good to know. I guess it was about time to add configurations.
I have only Kinesis Advantage 1. But I do not use it any more.
Offline Salt Peanuts
« Reply #22 on: Wed, 16 November 2016, 13:29:13 »
ETA of Q1 2017.
I have both Adv1 and Adv2.  Have not gamed with either one, though.
Offline vivalarevolución
« Reply #23 on: Wed, 16 November 2016, 19:53:25 »
who digs this stuff up
Offline davkol
  •  Post Editing Timeout
« Reply #24 on: Thu, 17 November 2016, 10:12:54 »
Yet another new user spamming worthless clutter, probably to boost their post count, so that they can buy/sell **** (very likely some "artisans" or whatever).
« Reply #25 on: Thu, 17 November 2016, 19:50:04 »
Wonderful.
