Author Topic: Any way to DIY pad print caps?  (Read 4746 times)
Offline TheVengeance
« on: Sun, 29 May 2016, 02:15:43 »
I've started making some caps including some blanks.
Has anybody made a diy pad printing jig? Is this something I could achieve with a 3d printer / other material?
Offline Hak Foo
  • Make America Clicky Again!
Re: Any way to DIY pad print caps?
« Reply #1 on: Sun, 29 May 2016, 15:17:40 »
Custom waterslide transfers might be a good option.
Overton130, Box Pale Blues.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Sun, 29 May 2016, 20:54:26 »
Silk screening could be an option. No luck with double-shot molds?
Offline TalkingTree
    • My projects
« Reply #3 on: Mon, 30 May 2016, 04:28:44 »
This guy on Youtube made a DIY pad printer, the video doesn't explain the details but I guess you can make the most of it; if not, you might wanna send him a message.
