Author Topic: [Computex 2016] Zeal's picture thread  (Read 31937 times)
Offline Zeal
    • Zeal Generation Inc.
« on: Sun, 29 May 2016, 14:04:54 »
Let me know what you want to see.. Will be heading over in about 30hrs from this thread post.
For your reference, last year's picture / Q&A thread (non-mobile friendly, beware): https://geekhack.org/index.php?topic=72472.0
Cherry Booth:
Jackpot
NOT MX clears :P
Ducky/Vortex Booth
Ducky Year of the Monkey. Dual anodized aluminum on the surface in black & gold.
Ducky Shine 6 poster. Includes built in adjustable mouse bungee.
Ducky Air. Bluetooth 3.0. LEDs turn off when in Bluetooth mode.
Ducky Calculator. Works as a calculator and numpad when plugged in.
Ducky Dyesub PBT keycaps
Ducky Secret M is around 10% lighter than the original Ducky Secret. Back part is now double shot PBT plastic for the extra RGB LED to shine through.
Japanese Omrons
Vortex
Clone of SA profile PBT from Vortex. Left handed TKL.
Clone of DSA profile PBT from Vortex. Extremely smooth surface compared to SP's DSA caps.
Not sure if Vortex OEM brand or subdivision...Split 60% keyboard felt a bit uneven (OCD triggered)
Flaretech clicky & linear wooting keyboard (left on the table of Ducky booth)
The clicky switch didn't have any tactile feeling or kickback. Just the sound of a click and the faintest click feedback ever.
Apparently Ducky designs the PCB for Flaretech, which would explain why it's at the Ducky booth. They could be sharing the same OEM as well.
i-Rocks Booth
MX stem ALPS-like switches
The clicky blue switch had the alps high tactile point, but lacked the 'umph' of the strong kickback. Depressing the switch past the tactile point also felt effortless, as if the stem collapses to the bottom like Topre. Weird feeling for sure.
KBParadise Booth
JD45s
Topre Booth
Topre told me only 200x of the following keyboard will be made... "just for fun"
Realforces
Can set different actuation points, namely 1.5mm, 2.2mm, 3mm. Topre rep told me that the "A" legend on Realforce RGB's will use the /\ legend. Expected release date is October 2016, before Christmas.
Varmilo
1.8kg (4lb) full brass keyboard...Covered in a firm and shiny coating, not rubbery. Moulded brass with a brushed finish.
Totoro!
Hard case for your keyboard. Final production version will use EVA foam top and bottom.
« Last Edit: Wed, 01 June 2016, 20:32:38 by Zeal »
Offline Zeal
Re: [Computex 2016] Zeal's picture thread
« Reply #1 on: Sun, 29 May 2016, 14:05:15 »
« Last Edit: Sat, 04 June 2016, 15:35:05 by Zeal »
Offline Zeal
« Reply #2 on: Sun, 29 May 2016, 14:05:26 »
Non keyboard stuff will be posted here.
Alphacool entering AIO scene as well
Asus 34" 3840x1440 curved IPS monitor & integrated Qi charger
24.5" NATIVE 240hz 1ms GTG G-Sync enabled TN panel with ~170 degrees FOV
ROG AVALON mitx case
Corsair
Cooler Master
In-Win
« Last Edit: Wed, 01 June 2016, 20:36:44 by Zeal »
Offline meiosis
  • Time
« Reply #3 on: Sun, 29 May 2016, 15:07:59 »
cool.
Keyboards:
Aripeko TKL
Offline munch
« Reply #4 on: Sun, 29 May 2016, 15:34:39 »
we need Ducky Secret M comparison pics and weight!
« Reply #5 on: Sun, 29 May 2016, 16:03:23 »
Wooting keyboards is supposed to be there. Probably Adomax also, who makes their switches -- they were there last year, and they are based in Taiwan.
Do please try them and tell us how they feel. Off-centre key presses, stabilisers and switch grittiness would be interesting to know about. In the long run, switch internals and what kind of plastic the sliders are made of.
I have started geeking out about mini-ITX format PC cases with interesting layouts. Cryorig has a couple new ones that they are showing at Computex, and Jonsbo also probably.
« Last Edit: Mon, 30 May 2016, 09:32:18 by Findecanor »
Offline icyskyz
« Reply #6 on: Mon, 30 May 2016, 04:51:51 »
Interesting! Didn't know that you would be coming to Computex every year!
I'll be there around at Computex for couple days as well, hopefully I will see you there!  :thumb:
My collections - flickr | HWS Keyng Collector |
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #7 on: Mon, 30 May 2016, 17:41:35 »
As many stand girl pictures as you can take.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #8 on: Mon, 30 May 2016, 17:45:37 »
Show me some Topre pls
Offline FrostyToast
  • Litshoard
« Reply #9 on: Mon, 30 May 2016, 18:06:55 »
Zeal you know what my preferences in women are.
Send me photos when you can.
Quote from: elton5354
Offline Prelim
« Reply #10 on: Mon, 30 May 2016, 19:12:53 »
this! ;)
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #11 on: Mon, 30 May 2016, 20:00:36 »
Vortex would be nice. :)
I've seen some interesting things from them recently on instagram.
Offline katushkin
  • Just the guy
« Reply #12 on: Mon, 30 May 2016, 21:22:17 »
On a serious note, as many pictures of the new Pascal architecture in action would be awesome  :thumb:
Offline captain
« Reply #13 on: Mon, 30 May 2016, 23:52:52 »
Make that VIDEO of the new Pascal architecture in action!  ;-)
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline Zeal
« Reply #14 on: Tue, 31 May 2016, 00:04:05 »
Sneak peak.. 138475-0138477-1138479-2
Rip phone pics are upside down w/e
« Last Edit: Tue, 31 May 2016, 00:07:32 by Zeal »
Offline SixtyLife
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline KnivesM
« Reply #16 on: Tue, 31 May 2016, 00:16:06 »
Others
Offline FrostyToast
  • Litshoard
« Reply #17 on: Tue, 31 May 2016, 00:17:02 »
Sneak peak.. (Attachment Link) (Attachment Link) (Attachment Link)
WHAT IS THAT SPLIT KEYBOARD  :eek:
Those ugly keycaps tell me it's a Poker.
Judging by their cringeworthy naming scheme with the pok3r I am guessing this will be something like
Po   ker
or maybe...
PokErgo
Please no.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #18 on: Tue, 31 May 2016, 00:19:00 »
Looking forward to all of Zeal's photos. They're the best and provide such a great coverage of the event. :thumb:
Offline nateth
« Reply #19 on: Tue, 31 May 2016, 00:29:25 »
It does exist!!! I was worried that it was just a prototype that would never reach production.
Offline FrostyToast
  • Litshoard
« Reply #20 on: Tue, 31 May 2016, 00:36:42 »
Also, Zeal, your photography game has gotten even worse than mine.
Upside down potato pictures of other pictures on LCD displays?
Are you drunk?
Offline mteinum
« Reply #21 on: Tue, 31 May 2016, 00:44:58 »
Offline FrostyToast
  • Litshoard
« Reply #22 on: Tue, 31 May 2016, 01:06:46 »
New 40% from vortex?
https://www.instagram.com/p/BGDGyEIJDNV/
Just looked at their instagram.
Pretty sick that they have their own molds for DSA and SA profile caps.
I wonder if we could do a groupbuy for those since IvanIvanovich He-who-shall-not-be-named has used Vortex caps for buys.
Offline krisst
« Reply #23 on: Tue, 31 May 2016, 01:17:34 »
Those DSA and SA profile keycaps is a welcoming thing for the community. If they are able to make good quality stuff that are same or better than SP, we could have more sets for groupbuys at a faster rate.
Offline SixtyLife
« Reply #24 on: Tue, 31 May 2016, 01:22:29 »
IIRC Vortex teased it on their facebook a while ago.
ah, shoulda known it was vortex based on the caps. thanks
Offline katushkin
  • Just the guy
« Reply #25 on: Tue, 31 May 2016, 06:55:55 »
Po   ker
or maybe...
PokErgo
Please no.
Pok4r. Just to be interesting and different  :rolleyes:
« Reply #26 on: Tue, 31 May 2016, 09:24:35 »
Has anybody here tried the EpicGear switches? They are at Computex.
Offline Jokrik
« Reply #27 on: Tue, 31 May 2016, 09:29:52 »
Zeallllll
I need dem babes.....
Offline 27
  • The Maple Man
« Reply #28 on: Tue, 31 May 2016, 09:36:05 »
2 things I want to see.  Babez and if Topre is showing off anything new.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline Suruga Devil
« Reply #29 on: Tue, 31 May 2016, 09:48:02 »
Top kek, you know as well as anyone else that we can only dream for new additions to Topre gear outside of Asia :-\
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #30 on: Tue, 31 May 2016, 10:15:06 »
They are showing off the Realforce RGB.
« Reply #31 on: Tue, 31 May 2016, 10:22:18 »
Color me surprised. Nice to see some progress on the part of Realforce.
Offline Zeal
« Reply #32 on: Tue, 31 May 2016, 13:54:09 »
Hey guys, sorry, collapsed as I returned home at 9pm (headed straight to Computex right after I came off the 5am flight). It's now 3am and what better time to kill during jet lag than to edit/upload pictures? Will be updating OP shortly. I didn't take many pics of babes yesterday, usually do that on the last day.
Offline FrostyToast
  • Litshoard
« Reply #33 on: Tue, 31 May 2016, 14:46:31 »
The best for last? I get it. That's cool.
But I'd rather have 3 days worth of babes.
Offline Zeal
« Reply #34 on: Tue, 31 May 2016, 15:07:31 »
tfw photoshop cs6 doesn't scale on 4k displays... Everything is tiny on 15.6"
  • sleever supreme
  • greyhat co-leader
« Reply #35 on: Tue, 31 May 2016, 15:55:55 »
no lightroom, zeal scrub confirmed.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #36 on: Tue, 31 May 2016, 16:09:51 »
It scales well for me...
Offline Zeal
« Reply #37 on: Tue, 31 May 2016, 16:32:05 »
Zeallllll
Make sure your wife isn't checking your monitor... :eek:
Offline Sneaky Potato
  • Gunslinger
« Reply #38 on: Tue, 31 May 2016, 18:18:56 »
HNNNGGG those topre boards.
Also, what's with the left-handed SA board?
Offline nugglets
« Reply #39 on: Tue, 31 May 2016, 18:31:09 »
Awesome pics, thanks!
Quick question: Was kind of hard to tell in the Year of the Monkey pics, does it have those stupid "fins" on the top of the board like the Shine 6 does? And were you able to tell if they had the PBT caps on the two boards? Wondering what those are like.
Offline Zeal
« Reply #40 on: Tue, 31 May 2016, 18:37:32 »
No fins for the mouse bungee. Only the top case is anodized aluminum, base is still plastic. Both YOTM and Shine 6 used ABS DS caps.
Offline nugglets
« Reply #41 on: Tue, 31 May 2016, 18:41:12 »
Awesome, thanks for the reply! The Ducky promo they put out last week said PBT caps on Shine 6/YOTM, which is why I asked. I figured it might be a little early to have them in production, though. Really hope they have them available when they go on sale. Would definitely step things up.
Oh ****, I just noticed the Shine 6 promo booth shows a side view with a cutout on the side of the case to let the RGB through. That's really interesting. Was that on the YOTM too?
« Last Edit: Tue, 31 May 2016, 18:44:19 by nugglets »
Offline kekman
  • quit life
« Reply #42 on: Tue, 31 May 2016, 18:51:02 »
those topre boards and vortex....  :eek:
Offline Lepidus
« Reply #43 on: Tue, 31 May 2016, 18:59:43 »
Woa, they are cloning SA and DSA? SA PBT!
Offline 27
  • The Maple Man
« Reply #44 on: Tue, 31 May 2016, 19:02:23 »
Wow nice to see topre is bringing the adjustable actuation point to market.  I remember there was a lot of speculation about it last year.
Also ty for booth babez, you really know how to make a man happy.
Offline katushkin
  • Just the guy
« Reply #45 on: Tue, 31 May 2016, 19:07:12 »
So many black squares :(
Stupid work computers
Offline Burt Macklin
« Reply #46 on: Tue, 31 May 2016, 19:33:28 »
SA clones - YES, please  :thumb:
Any info on availability without the board, maybe?
Ducky numpad - oh, so it doesn't work in wireless mode? Calculator only?
« Reply #47 on: Tue, 31 May 2016, 19:37:06 »
Gimme that calculator. I need something to fill the void in my life left by the sub-par quality of the Alpsulator. Also so sick to see jdcarpe getting credit for a product featured at Computex!
« Reply #48 on: Tue, 31 May 2016, 19:48:05 »
Oh snap. I didn't see that JD45. That is awesome. Way to go jdcarpe.
Offline slickmamba
« Reply #49 on: Tue, 31 May 2016, 19:58:51 »
cool
Hi :)
