Author Topic: Do you know anything about these boards?  (Read 4614 times)
Offline HeeCh2ei
  • qdrw
« on: Mon, 30 May 2016, 11:08:03 »
My friend discovered some ancient stuff.
I have found no info about these things so maybe someone can shed some light
I think the old soviet one uses the reed switches
138417-0
Mycron Datasystemer TDV 2200 / 22 S
138419-1
Hewlett Packard 46021AD
138421-2138423-3
Xerox 8RR
138425-4138427-5
Caps looks like the typewriter can have some old mx switches underneath.
UPD: he said that the mycron is on the rubber domes
« Last Edit: Mon, 06 June 2016, 07:36:30 by HeeCh2ei »
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline Red October
Re: Do you know anything about these boards?
« Reply #1 on: Mon, 30 May 2016, 12:02:12 »
Afraid all I can say is that the first one looks like it goes to a Soviet clone of a DEC system, it has elements of both VT100 and VT220 keyboards.  The second one is a thing of beauty.
I've got one of those HP boards, they're nothing special.  Somewhere I have a PS/2 version of that board, but I can't for the life of me find it.  Not a big problem, though, because, again, it's not an inspiring keyboard to type on, although it is neat to look at.
Offline HeeCh2ei
  • qdrw
« Reply #2 on: Mon, 30 May 2016, 12:15:51 »
Thanks.
I thought that HP have some buckling springs or something like that.
« Last Edit: Mon, 30 May 2016, 13:12:10 by HeeCh2ei »
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Mon, 30 May 2016, 12:35:59 »
IBM's are the ones with buckling springs, though ALPS made a few of their own and there was one or two chinese knockoffs of them, neither of which are these boards.
Offline HeeCh2ei
  • qdrw
« Reply #4 on: Mon, 30 May 2016, 14:00:22 »
Ok. Thanks for the info. I really not that much into the vintage boards.
There is some cyrillic WYSE which I want to grab. He throw the second one in trash, because it lost too much caps.
WYSE PCE 840362-01
138429-0 138431-1
« Last Edit: Mon, 30 May 2016, 14:12:28 by HeeCh2ei »
Offline rwiker
« Reply #5 on: Mon, 30 May 2016, 14:06:57 »
The Mycron is probably from an OEM version of the Tandberg TDV 2200 serial terminal. Both Tandberg and Mycron were Norwegian computer companies. Tandberg also made a very similar PC keyboard.
The keyboard switches are (I believe) Cherry ML.
Offline HeeCh2ei
  • qdrw
« Reply #6 on: Mon, 30 May 2016, 14:32:49 »
There is almost impossible to find something about this keyboard. Thanks.
« Last Edit: Mon, 30 May 2016, 14:38:11 by HeeCh2ei »
Online Findecanor
« Reply #7 on: Mon, 30 May 2016, 16:03:05 »
The HP has rubber domes. It uses HIL bus signalling which was proprietary for HP. (I have had one)
I have seen a Tandberg or Mycron terminal keyboard with keys that looked like that but instead of Cherry ML, it had Ericsson switches.
The Wyse has most likely Cherry MX Black switches, but the keyboard uses a proprietary protocol. There should be firmware for a Teensy/AVR-based converter from WYSE to USB.
« Last Edit: Mon, 30 May 2016, 16:05:54 by Findecanor »
Offline HeeCh2ei
  • qdrw
« Reply #8 on: Tue, 31 May 2016, 06:50:15 »
Thanks a lot.
I am know about Wyse boards, there is no problem to find information on them. I'll have to take that one dirt cheap, exclusively for switches and caps.
And soon for the typewriter some photos with pulled caps will arrive. I hope it contains cherry mx switches with compatible caps.
I have a huge plans for that stuff.
Offline HeeCh2ei
  • qdrw
« Reply #10 on: Tue, 31 May 2016, 07:17:53 »
i like the xerox caps!
Sure. Pretty ghetto legends. I rate that unique font much higher than the default Deck font. No, I'll plan to sand it down.
Offline HeeCh2ei
  • qdrw
« Reply #11 on: Mon, 06 June 2016, 06:49:01 »
Some pics of a typewriter with removed cap are arrived. Wtf is that? Looks like rubber domes over the springs.
« Last Edit: Mon, 06 June 2016, 06:56:22 by HeeCh2ei »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #12 on: Mon, 06 June 2016, 07:22:34 »
Amstrad spring over membrane. The second-worst switch I've ever tried.
Run. Run away and never look back.
Offline HeeCh2ei
  • qdrw
« Reply #13 on: Mon, 06 June 2016, 07:34:14 »
Thanks. I already refused on this item.
And what is the most worstest switch you tried?
« Last Edit: Mon, 06 June 2016, 07:35:50 by HeeCh2ei »
Offline chyros
  • a.k.a. Thomas
« Reply #14 on: Mon, 06 June 2016, 07:41:26 »
I reviewed a Smith-Corona electronic typewriter module yesterday with a hideous type of leaf spring over membrane. A bizarre switch that felt so bad I could barely think of a way to even describe it.
