Author Topic: Smoothest MX or MX-Compatible Linear Switch?  (Read 8141 times)
Offline Suruga Devil
« on: Mon, 30 May 2016, 14:56:38 »
MX Reds don't cut it for me anymore. Even with bike chain oil as lube, these things still scratch beyond belief. Looking to go ham with a custom upgrade.
In your opinion, what is the smoothest MX or MX-Compatible switch? Anything goes here, as long as it's MX, so mixing and matching parts is kosher. Also, for you guys who are experienced with switch lubes, which one provides the smoothest experience?
Right now I'm thinking that Linear Zealios might be the key, with polishing and lubricating. Thoughts?
Offline klennkellon
  • I like bottoming out
Re: Smoothest MX or MX-Compatible Linear Switch?
« Reply #1 on: Mon, 30 May 2016, 15:01:22 »
Lubed Gaterons?
or ideally,
Linear ALPS with ALPS to MX adapters.
Offline jacobolus
« Reply #2 on: Mon, 30 May 2016, 15:02:38 »
“Vintage” MX black switches from the mid-1980s are a lot nicer than modern ones. Probably as good as any MX clone you’ll find.
Offline pr0ximity
« Reply #3 on: Mon, 30 May 2016, 15:13:31 »
Vintage MX are the best linears I've tried, and I have a nice sampling of linears at my disposal.
SKCL are very nice, but have subtle tactility and are very prone to contamination.
Gateron are incredibly smooth, I'd almost say more than vintage MX, but their plastic is very soft.
Regardless, lube them with the thinnest Krytox oil you can get ahold of: 100-series, the lower number the thinner the oil is, 100-103 would probably be best.
« Last Edit: Mon, 30 May 2016, 15:15:03 by pr0ximity »
Offline mind_funeral
  • savior of lost fortunes
« Reply #4 on: Tue, 31 May 2016, 07:50:45 »
GATERON
Poker II.3 with Gateron Browns and SIP sockets,  Midnight/Twilight DCS
KBP V60 with Gateron Clears, EnjoyPBT Cyrillics
Topre Type Heaven
Offline SBJ
  • Tactile pls
« Reply #5 on: Tue, 31 May 2016, 08:04:27 »
Lubed Gaterons?
or ideally,
I'm using stock Gaterons right now and they feel really smooth. Lubing them seems like it'd be a fun project however.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Tue, 31 May 2016, 10:26:50 »
Probably Gaterons or vintage blacks. The smoothest linear switches aren't MX-compatible, though.
Offline Jibsey
« Reply #7 on: Tue, 31 May 2016, 10:34:07 »
Gateron Clears are quite smooth. But I feel like the light actuation force contributes to that as well slightly.
Offline merlin64
    • MechMerlin
« Reply #8 on: Tue, 31 May 2016, 10:43:21 »
You need to use grease instead of oil to lube it. Oil will just sit at the bottom, grease will remain on the sliders.
My experience has been 80s vintage blacks and Gaterons are the smoothest Cherry MX switches.
« Reply #9 on: Tue, 31 May 2016, 14:22:29 »
Yeah, if there were such things as new Hall Effect switches with MX-compatible mounts, I'd burn a village to get them.
As of now, MX is the best I've got.
« Reply #10 on: Tue, 31 May 2016, 14:25:57 »
Nah. SKCM Green Alps are smoother imo. And they're attainable/usable now. But if you're stuck on MX mount, I'd go with lubed Gateron Blacks.
« Reply #11 on: Tue, 31 May 2016, 14:38:23 »
Good to know. I've heard that Green Alps are smoother, but I've always taken that assessment with a grain of salt since there's probably a bias among Alps owners to how good the switches are. I can consider options, though finding keysets for Alps is supposedly a nightmare  :-\
« Reply #12 on: Tue, 31 May 2016, 14:42:56 »
You asked a very subjective question. Should be prepared for a very subjective answer. No one has measured friction coefficients of switch stems yet so every answer will not be objective. Including mine....especially if I'm talking about Alps lol.
« Reply #13 on: Tue, 31 May 2016, 15:02:59 »
Very true. The consensus on MX-compatible switches seems to be that Gateron takes the crown in the linear department. I'll see how lubed Gateron Blacks work out, thank you all for your help!
Offline chyros
  • a.k.a. Thomas
« Reply #14 on: Tue, 31 May 2016, 16:02:51 »
Alps-mount is probably the second-easiest mount to get caps for. Although admittedly, it's a big difference with Cherries xD .
Alps are eally nice, but they're old AND susceptible to dust; not a great combination. This is a major reason why people's opinions on them vary, I think.
By the way, if you want linear Alps, you don't necessarily need greens. Even blacks, when linearised, are super smooth, just as good as greens IMO. Greens come in really cool boards though :) .
« Reply #15 on: Tue, 31 May 2016, 20:06:39 »
Aren't the linear Zealios already lubed?
« Reply #16 on: Wed, 01 June 2016, 06:58:50 »
Oh, yeah, I just checked and they are. I'd honestly jump on them right away if there were any in stock, but for now the Gateron Blacks are coming in.
Offline Harms
« Reply #17 on: Thu, 02 June 2016, 21:06:33 »
No one likes Gateron Red :O. My persona; fav :D
« Reply #18 on: Thu, 02 June 2016, 21:23:08 »
Nixdorfs... wtf is this even a question
Offline jamster
« Reply #19 on: Thu, 02 June 2016, 23:23:50 »
Depending on what you mean by MX-compatible, then Royal Kludge type Topre clones. The factory dental banded thing makes them feel very close to linear, and they are way smoother than Cherry switches. Compatible with normal key caps.
Offline mason
  • have fun with her, ryan
« Reply #20 on: Thu, 02 June 2016, 23:34:34 »
1. Vintage blacks with stock springs
Offline pr0ximity
« Reply #21 on: Fri, 03 June 2016, 20:36:06 »
I might actually prefer unlubed ones. They're extremely smooth already, and the rebound feels different to me on my lubed and unlubed Gateron Blacks.
Truth.
« Reply #22 on: Sat, 04 June 2016, 13:52:25 »
Off topic, but do the Zealios tactile switches come lubed?
Topre Type Heaven
Offline davkol
  •  Post Editing Timeout
« Reply #23 on: Sun, 05 June 2016, 04:38:45 »
Yup.
Offline kekman
  • quit life
« Reply #24 on: Sun, 05 June 2016, 06:10:13 »
fill the switch housings with jelly for that frictionless experience  :cool:
functionality not guaranteed
