Author Topic: The start of a new video series inspired by Chyrosran22 Cherry MX Blacks Review  (Read 8103 times)
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
This will be the start of a new series reviewing actual switches as opposed to the keyboard they are on.  I intend to go through every switch i own/Ones i have owned and used for at least 1-2 months.   Chyrosan22 inspired me to do this as i really enjoy his series on all the different ALPS switches and thought to myself i'd love to do something similar on Cherry/Cherry Clones/Topre.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
I inspired someone? That's awesome! xD
Good luck man! :D
Offline ThoughtArtist
I have some MX Browns in a KUL that are VERY scratchy, but in a Varmilo I have MX Browns that are much smoother. I wonder why and I wonder which of those are closest in the scratchiness with the newer MX Blacks you have.
« Last Edit: Sat, 04 June 2016, 21:28:14 by ThoughtArtist »
I do wonder how much a break in period will effect them also,my MX Black board is still relatively new.
Offline HeeCh2ei
  • qdrw
It's just a crappy batch.
In my first mech browns was extremely scratchy, to the point were any "break in" can't possibly helps. In my current board on reds about 90% of switches is smooth (and a lot of people describe reds as awfully scratchy).
So, in such MX inconsistency from batch to batch any opinion is futile. Buying keyboard on mx is the same thing like rolling the dice.
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Good luck :)
I'm sure that you'll have plenty of keyboards to review in the future.
Good luck :)
As it stands besides the MX Blacks i have already reviewed i have the following to do (Also with O-Ring commentary both 0.2MM and 0.4MM on each switch to comment what difference it makes)  Will go back and comment on MX Blacks in the future far as Orings go.
Mx Blues
Mx Browns
Mx Reds
Mx Clears
Mx Greens
Mx Whites
45 G HHKB Topre
55G Realforce Topre
Matias CLicky
Black Alps
Cherry ML
