Author Topic: Removing keycaps from an Apple Extended Keyboard II?  (Read 6847 times)
Offline spremino
« on: Wed, 01 June 2016, 18:33:25 »
I was reading a cleaning guide for the Apple Extended Keyboard II, when I stumbled on this paragraph:
One other thing that didn’t change: the key caps are not easily removed, so my recommendation doesn’t change. Don’t attempt to remove the key caps.(source: http://lowendmac.com/2006/apples-extended-keyboard-ii-sequel-to-a-legend/)
Is this really the case?  Or did the author ignore the existence of keycap pullers?  Thank you.
A long space bar... what a waste of space!
Re: Removing keycaps from an Apple Extended Keyboard II?
« Reply #1 on: Wed, 01 June 2016, 18:37:40 »
I have a set, and many others have sets to use on other boards. It seems totally fine to remove them.
« Reply #2 on: Wed, 01 June 2016, 21:59:04 »
Probably ignorance of wire keycap pullers.
Online Findecanor
« Reply #3 on: Thu, 02 June 2016, 00:18:52 »
You have to be more careful when pulling Alps keycaps than Cherry keycaps. The Alps stems often sit tighter and break more easily.
Offline mike52787
  • Alps Aficionado
« Reply #4 on: Thu, 02 June 2016, 11:26:05 »
I think the idea of not removing the caps is for people without a keycap puller, if you pry off really tight alps keycaps(ones that havent been removed before) it is really easy to break the stem off inside the slider.
Offline Moistgun
  • Slippery When Wet
« Reply #5 on: Thu, 02 June 2016, 12:06:16 »
I assume they have just broken alot of caps. I took mine off a number of times with a cap puller.  no problem. just be careful.
Offline emdude
« Reply #6 on: Thu, 02 June 2016, 23:38:33 »
Yes, as others have pointed out, they are difficult to remove so you need to be careful.  You will need to pull straight up with a key cap puller to remove them safely.
Current drivers: IBM Model M SSK
