Author Topic: Really cool model m with multicolored keycaps and trackball  (Read 3706 times)
Offline mike52787
  • Alps Aficionado
« Last Edit: Thu, 02 June 2016, 21:50:45 by mike52787 »
Offline zombiegristle
Re: Really cool model m with multicolored keycaps and trackball
« Reply #1 on: Thu, 02 June 2016, 21:51:25 »
Can someone more educated than I confirm, this is buckling-spring over membrane, yes? Pretty sure I'm about to buy it.
EDIT: Yep, yoink'd. Thanks much for the tip!
« Last Edit: Thu, 02 June 2016, 21:58:01 by zombiegristle »
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Thu, 02 June 2016, 21:58:40 »
EDIT: Yep, yoink'd.
Good for you! That is definitely a cool board. If I wasnt so wallethacked at the moment I might have popped for it. Make sure to post some better pics of it! Im sure alot of people here would love to see it in better non potato quality.
« Reply #3 on: Thu, 02 June 2016, 22:02:42 »
Yup, I'll be picturizing it up while I give it the customary used-keyboard-deepclean. I was in the market for a buckling spring but couldn't figure out what I wanted, so this just made everything easy - and the seller is only a few hours' drive away to boot, so it should be here soon. :D
