Author Topic: Weird linear alps switch (sharp pc-7000 keyboard)  (Read 5274 times)
Offline mike52787
  • Alps Aficionado
« on: Sat, 04 June 2016, 17:16:35 »
Here is the board. Ive never seen one of these switches, and I cant find it on the DT wiki. They are really mushy and feel like **** imo.
The lock keys have alps skfl switches with leds built in. See if you can id the other switch.
Here are a few pics of the pcb with alps part numbers.
Any help identifying these switches is greatly appreciated. Even though they arent very good, Im curious what they are.
« Last Edit: Sat, 04 June 2016, 17:18:07 by mike52787 »
Offline klennkellon
  • I like bottoming out
Re: Weird linear alps switch (sharp pc-7000 keyboard)
« Reply #1 on: Sat, 04 June 2016, 17:42:47 »
They look like ALPS SKFL.
https://deskthority.net/wiki/Alps_SKFL_series
Dirty ALPS can feel nasty so that might explain the **** feeling.
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Sat, 04 June 2016, 17:45:09 »
No, the other switch, if you read my post I said I know what the lock switches are. These may be a new discovery, I went through all of the dt alps switch pages and I couldnt find anything like that. They have small alps logos cast into the top shell of the switches also.
Offline emdude
« Reply #4 on: Sat, 04 June 2016, 17:50:35 »
As nubbinator has said, it looks like Alps Integrated Domes with white sliders instead of blue ones like in the photo below.
Current drivers: IBM Model M SSK
Offline mike52787
  • Alps Aficionado
« Reply #5 on: Sat, 04 June 2016, 17:52:05 »
Thanks nubbs and emdude. I knew these felt like **** for a reason, theyre just domes!
« Reply #6 on: Sat, 04 June 2016, 17:55:05 »
Yeah, more pics with the white.  It does look like there's no consensus on who made them, just that they're alps compatible.  The fact that they're on a board with Alps switches does indicate that they're probably Alps made though.
Offline jacobolus
« Reply #7 on: Tue, 28 June 2016, 00:50:08 »
These were definitely Alps made. If you desolder one there’s probably a logo on the bottom.
