Author Topic: To all fellow Europeans  (Read 2620 times)
Offline Malenky
« on: Sun, 05 June 2016, 17:24:29 »
After being so annoyed by "ISO kits" in keysets having only ISO enter and some random other keys which do not match ISO-UK layout, I eventually bit the bullet and made the transition to ANSI. While the benefits of shift and enter being close to the home row are great, the one thing I still missed so regularly was the £ symbol. Then I found this blog:
https://blog.ginkel.com/2010/05/us-international-keyboard-layout-wo-dead-keys-for-microsoft-windows/
The layout is there for you, but the software it talks about basically allows you to create your own keyboard language to suit your keycaps. I now have £ on shift-altgr-4, which makes perfect sense to me as it's a modifier of $. The software allows you to create your own layout and then create a pack to install it. All you have to do after install it sign out and in (or restart) and then you can choose it from your input languages.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: To all fellow Europeans
« Reply #1 on: Sun, 05 June 2016, 17:30:45 »
ANSI is wasteful of space, I think personally, and the return key is just horrendous.
If you want £, either stick your layout on UK, or be oldschool like me and use alt+156 ;) . Left alt and numpad numbers or it won't work.
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Sun, 05 June 2016, 17:30:49 »
MS Keyboard Layout Creator is a neat thing to know.
There's one noteworthy alternative: Portable Keyboard Layout, that embeds an AHK keymap into a simple binary file, that doesn't require installation.
Offline xondat
  • i'm not a star
« Reply #3 on: Sun, 05 June 2016, 17:33:53 »
Not having the pound sign on my keyboard is the most annoying thing using ANSI. I've never made the effort to get it though, however I should tomorrow when I have nothing else to do. I like the idea of having shift-altgr-4 but I'll have to see.
Offline Almost
  • Zs Xe
« Reply #4 on: Sun, 05 June 2016, 17:36:11 »
This is quite nifty, thanks for posting!
Ex-ISO user on ANSI now, got away with it by just having the PC set to United Kingdom layout. £ is Shift-3 like on ISO. Only thing missing is \| key
Backwards slash I memorised as Alt 92 on a numberpad untill I realised I could set up macro's in autohotkey (I'm a slow learner!).
Gonna try this out sometime though.  ;D
Kbds: KOBO Red Carbon - Filco MJT2 Beige - Topre U23 - Cherry 3700 - Model F XT 5155
Sets: Dolch R1 - Red Alert - Hyperfuse R1 - Cherry WoB - Plum
Offline appleonama
  • Trollo en USA
« Reply #5 on: Sun, 05 June 2016, 17:38:33 »
praise it brother.  :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
ISO is dumb
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Sun, 05 June 2016, 18:39:26 »
Alt keys are the answer to everything. Memorise them all mofos .
Offline xondat
  • i'm not a star
« Reply #7 on: Sun, 05 June 2016, 20:15:21 »
Slight problem. I look down and it turns out I don't have a numpad!
Offline Bucake
« Reply #8 on: Sun, 05 June 2016, 20:17:34 »
..oh my god! my keyboard has the same defect!
Offline chyros
  • a.k.a. Thomas
« Reply #9 on: Mon, 06 June 2016, 02:16:55 »
Hahaha and now everyone knows why I like fullsize layouts so much  :)) .
Offline Bucake
« Reply #10 on: Mon, 06 June 2016, 02:25:47 »
yeah, the lack of numpad shortcuts is one of the reasons why i sometimes miss the numpad. but for the pound sign, Shift + Ctrl + Alt + 4 works fine for me. not sure if all input languages support that shortcut, though. i'm using US-International
« Last Edit: Mon, 06 June 2016, 02:27:26 by Bucake »
Offline SBJ
  • Tactile pls
« Reply #11 on: Mon, 06 June 2016, 08:53:12 »
I personally use EurKey.
Offline MrFex
« Reply #12 on: Mon, 06 June 2016, 09:24:22 »
I opt for an AHK script:
Code: [Select]
