Author Topic: Numeric keypad as an extension keypad?  (Read 2580 times)
Offline QuincyJones
« on: Mon, 06 June 2016, 21:50:22 »
So, here's an idea.
1. Buy a cheap laptop numeric keypad
2. Write an application / driver that can target a specific usb device and alter the keycodes on the fly
3. Target the keypad device and map keycodes to some unused codes
4. Use autohotkeys to do cool things with the new keycodes (assuming it sees the new keycodes, not the old ones).
5. ?????
6. Profit!
Is this feasable?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline FrostyToast
  • Litshoard
Re: Numeric keypad as an extension keypad?
« Reply #1 on: Mon, 06 June 2016, 22:03:27 »
This might help you out.
You just plug your keypad into this and then plug the converter into your PC and it will replace whatever keys you want with whatever macros you want.
Quote from: elton5354
Offline zombiegristle
« Reply #2 on: Mon, 06 June 2016, 22:06:11 »
Well, that's a nifty little piece of cable.
Offline QuincyJones
« Reply #3 on: Mon, 06 June 2016, 23:14:05 »
the converter price is criminal compared to how much you can buy them for from china  - $0.1-1.25 / Piece
(please like me)
« Reply #4 on: Mon, 06 June 2016, 23:18:10 »
Do those ones also have the programmable controller inside the cable?
Offline Bucake
« Reply #5 on: Mon, 06 June 2016, 23:29:38 »
not that orihalcon's cables are cheap, but i very much doubt that those chinese ones have similar hardware inside. they're likely just passive adapters.
Offline QuincyJones
« Reply #6 on: Mon, 06 June 2016, 23:49:41 »
Welcome to Chinese prices! And yes, they include all the reprogrammable stuff. Where do you think that lead came from in the first place?
« Last Edit: Mon, 06 June 2016, 23:52:08 by QuincyJones »
(please like me)
Offline ddot
  • Master of Suspense
« Reply #7 on: Tue, 07 June 2016, 00:06:14 »
I remember a similar thread from several years ago.  HID macros is a Windows based program that could intercept keycodes and assign macros.  Not quite as elegant as a programmable cable, but the price is right.  See my old post here:
https://geekhack.org/index.php?topic=35588.msg666122#msg666122
Offline QuincyJones
« Reply #8 on: Tue, 07 June 2016, 01:23:03 »
Interesting - thanks! I came across this along the same vein - https://autohotkey.com/boards/viewtopic.php?t=7545
It seems crazy to have to buy a cable to reprogram a functioning keyboard! (And I'm too frugal!)
(please like me)
Offline QuincyJones
« Reply #9 on: Tue, 07 June 2016, 17:08:58 »
Has anyone hacked together something as simple as a few of these together:
 www.ebay.co.uk/itm/4x4-Matrix-Keypad-Keyboard-module-For-Arduino-atmel-Stmap-S1-2-16-Botton-mcu-/141743413701
I'd imagine the combining of the matrices would be a pita, and finding keycaps awkward, but a quick dirty custom solution with plenty of possibilities?
(please like me)
