Author Topic: NOOB Topre Keycap question  (Read 14652 times)
Offline les_garten
« on: Tue, 07 June 2016, 16:27:07 »
I'm interested in the Topre Full sized keyboards like Type Heaven and Realforce
Looking in the Keycap GB section, will the title list if it is for Topre?
I'm assuming that somewhere within a Blue Moon time frame someone does a Topre set?
Are there some keycap sets that will fit Cherry MX and Topre?
For something as simple as keyboards, this is some complicated stuff.
I've been "computing" since '85, can't believe how much cool stuff I have thrown away...
some within the last year or so   :(
Offline phoible
Re: NOOB Topre Keycap question
« Reply #1 on: Tue, 07 June 2016, 19:57:08 »
Pretty much no keycaps are compatible with Topre, with the exception of some sets that Topre manufactured (I believe they don't do this any more) and a few artisan keycaps.
The CM Storm Novatouch uses Topre Switches, but has custom sliders that are compatible with MX keycaps. It isn't compatible with Topre keycaps.
Some people have bought Novatouches and harvested the sliders to use them in a Realforce, HHKB, or Leopold FC660C. This is a fairly expensive proposition, though, and you would need to take apart Two Novatouches to do a full-sized Type Heaven or Realforce.
You can also buy one of the keyboards with knock off Topres, which have MX-compatible sliders. The sliders will work in all non-stabilized Topre keys.
I think that one time there was a Topre keyset on Massdrop, but it didn't sell enough to hit the minimum order quantity.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Tue, 07 June 2016, 20:22:25 »
Topre sets are available but they're expensive as ****. Sellers on Ebay sell them, Taobao merchants sell them, hell even vendors on Amazon keep a few in stock. A lot of people dye the caps they want to change or send the keys off to be dyed by someone that has done it a bunch of times. Usually they'll list them as Realforce keycaps or HHKB keycaps. So far I've yet to see aftermarket keys for Type Heaven.
« Last Edit: Tue, 07 June 2016, 20:24:38 by csmertx »
Offline nmur
  • ಠ_ಠ
« Reply #3 on: Tue, 07 June 2016, 20:55:03 »
almost every keyset you'll see in the Interest Check and Group Buy subforums are MX, unless explicitly stated
no retail stores have any stock of ANSI topre sets as they haven't been produced for a while now, however a few of them are generally available on ebay or such for $150 USD. this is generally the price point people seem to sell at for aftermarket sales too.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Tue, 07 June 2016, 21:10:49 »
They're not easy to find for USA types, but they're available. Taobao is jam packed with ANSI Topre keysets from what I've seen.
Here's a Taobao link with ANSI keycaps in a five different colors. Same price point though :/
https://world.taobao.com/item/36392535695.htm?fromSite=main&spm=a1z3o.7695460.0.0.P6OabG
Offline les_garten
« Reply #5 on: Tue, 07 June 2016, 22:30:10 »
If you buy a Novatech to get the sliders to do the MX conversion, how do you deal with getting the stabilzed keys converted?
Offline les_garten
« Reply #6 on: Tue, 07 June 2016, 22:30:46 »
How do they keep the legends if they dye them?
Offline les_garten
« Reply #7 on: Tue, 07 June 2016, 22:31:43 »
That explains what I am seeing in the Topre picture thread, thanx!
Offline les_garten
« Reply #8 on: Tue, 07 June 2016, 22:38:59 »
It seems to me if I was Topre, I would adopt the MX compatible sliders across the whole range of switches.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #9 on: Tue, 07 June 2016, 22:46:45 »
I'm guessing that folks only use light dye colors if the keycaps have dye-sub legends? I mostly see dyed blanks tbh
Here is the Topre Keyboard picture thread https://geekhack.org/index.php?topic=40658.0
Offline les_garten
« Reply #10 on: Tue, 07 June 2016, 22:48:59 »
Yeah, I'm browsing that thread now.
Wish CoolerMaster made a 104 Novatouch...
Then you could get all the sliders
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #11 on: Tue, 07 June 2016, 22:56:01 »
Yup. The only problem with Novatouch sliders is that some artisans make caps that won't fit on hybrid stems. My guess is that the stem design makes the cap stronger /shrug I guess that's only a problem if you want to deck out your entire keyboard with those kinds of artisan caps :confused:
Offline les_garten
« Reply #12 on: Tue, 07 June 2016, 23:07:59 »
I'm not a fan of those Caps so that doesn't apply to me.
I just picked up my first Topre off Ebay from EK a few minutes ago!
I got it for my wife to use at work.  It's a Type Heaven.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Tue, 07 June 2016, 23:17:39 »
Legit topre switches nice :)
Offline phoible
« Reply #14 on: Fri, 10 June 2016, 00:48:28 »
The Novatouch sliders for the stabilized keys should work with the stabilized keys on a Topre board.
The problem I mentioned with the stabilized sliders is only for the knock-off Topre switches (like the Royal Kludge EC930).
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #15 on: Sat, 11 June 2016, 17:27:37 »
Doubt it will happen since Topre will be releasing their RGB Realforce — which has Topre x MX plungers and a standard layout — in the near future :
Offline superdh
« Reply #16 on: Wed, 26 October 2016, 16:47:42 »
I have a 105UB realforce keyboard and i want keycaps with hangul text on them.
Then i realised the lack of topre keycaps on the market. So i found these "Topre to MX adapter" on aliexpress.
How easy would it be to fit these in to my switches?
Anyone know if there are any problems with these?
« Reply #17 on: Wed, 26 October 2016, 16:50:32 »
Topre to MX stems are fairly common now.
To install them, you will need to take the board apart. It's not an especially difficult mod to do (no soldering involved), but it is time consuming.
Also, taking apart a Topre board can be kind of a PITA. I've never done it, but I've heard a lot of stories.
Do a little googling around to learn more about it.
Offline les_garten
« Reply #18 on: Wed, 26 October 2016, 19:07:32 »
WOW!  At that price, you would be better off getting some folks together and buying 500 pieces.
Offline 1swt2gs
  • DOGE
« Reply #19 on: Wed, 26 October 2016, 19:45:08 »
Hmm, I wonder how much a full 104 set in TMX would cost :O
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
« Reply #20 on: Wed, 26 October 2016, 20:45:05 »
A ****load, until the stems get standardized, then probably $120 a set.
Offline les_garten
« Reply #21 on: Wed, 26 October 2016, 21:17:40 »
They are only about $25 a set if you get 3 other folks to go in on getting bulk pricing.
« Reply #22 on: Wed, 26 October 2016, 21:30:31 »
Not the sliders, I'm talking about keycaps made by a manufacturer.
Offline les_garten
« Reply #23 on: Wed, 26 October 2016, 21:55:19 »
Gotcha, yeah High $$$ for sure
Offline cicada
  • Formerly iamacicada
« Reply #24 on: Fri, 28 October 2016, 13:37:45 »
« Last Edit: Sat, 14 March 2020, 11:13:08 by iamacicada »
« Reply #25 on: Fri, 28 October 2016, 14:27:56 »
I wonder which manufacturer will be the first to make TMX keycaps. On a side note, does anyone know where I can get a Topre pink blank set that isn't $400?
You can't.
They're not made anymore, so you'll just have to wait. I was fortunate enough to get a topre keyset in a trade a while ago, but now they're incredibly hard to come by.
Offline Crapbag
« Reply #26 on: Fri, 28 October 2016, 14:31:35 »
Are TMX Keycaps even possible?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #27 on: Fri, 28 October 2016, 16:00:32 »
If you build it--people will buy all of it and flip it for profit. I think Nubbinator is working on something that could potentially be pretty awesome
Offline gaztec
« Reply #28 on: Fri, 25 November 2016, 15:45:33 »
A Bit more variety and selection in Topre keycaps would be great.  :thumb:
Offline sashi
« Reply #29 on: Mon, 28 November 2016, 16:31:28 »
Kinda want to get a tad bit off topic.. but are there any keycaps for the FC660c?
Is the only way to get it is from a novatouch conversion? Or would those aliexpress Topre to MX stems work fine?
