Author Topic: Das Keyboard III (Professional) on PS/2?  (Read 2761 times)
Offline Sniper257
« on: Sun, 27 December 2009, 01:06:22 »
So I got myself a Das Keyboard Professional for Christmas, my first tactile switch keyboard, and I love it... the only problem I have with it is the 6-key rollover limitation imposed by USB.  Is there any way possible to use this keyboard with PS/2 and get full n-key rollover?  It doesn't flat out support a standard USB -> PS/2 adapter though.  Any help is appreciated, thanks!
Offline ch_123
« Reply #1 on: Sun, 27 December 2009, 05:09:56 »
Nope. The newer model does, but not the Das 3.
PS/2 to USB is not a straight forward process. For all intents and purposes - if the keyboard doesn't come with a PS/2 to USB adapter in the box, it cant be done.
Offline Rajagra
« Reply #2 on: Sun, 27 December 2009, 05:31:19 »
Only the most recent DAS III S version can give full n-key rollover over PS/2. That one had teething problems, though, I've yet to see a review/test of the fixed revision.
The older version (non-'S') is USB only.
But remember the USB limitation is 6 keys plus modifiers. You can press ANY combination of 6 keys plus Ctrl/Alt/Shift safely. That isn't a bad limitation really.
Also the DAS III (old) has an odd way of handling 12 keys at once - it repeatedly sends codes for the first six, then the other keys are sent, and it alternates these. It appears to the PC as if you are hammering away at those (up to) 12 keys. If you really need more than 6 keypresses at once, then it might help. It might not. Like I said, it's an odd workaround.
Offline Sniper257
« Reply #3 on: Sun, 27 December 2009, 08:49:48 »
Alright then, thanks!  I use my keyboard for rhythm games, and being able to press 8 at a time is sometimes necessary but I guess that's not a big issue.  It's still a dream to type on compared to my crappy-ass rubber dome Logitech Internet Navigator.
Offline Sniper257
« Reply #4 on: Sun, 27 December 2009, 10:42:07 »
I've already got a dedicated controller with arcade buttons, the keyboard is just for whenever I don't feel like going all out :D
Offline ricercar
  • mostly abides
« Reply #5 on: Sun, 27 December 2009, 10:58:08 »
Quote from: ripster;145561
For rythym games
Are those anything like "rhythm" games?
Offline Sniper257
« Reply #6 on: Sun, 27 December 2009, 12:55:29 »
Quote from: ricercar;145588
oh you
Offline ricercar
  • mostly abides
« Reply #7 on: Sun, 27 December 2009, 13:56:32 »
I can't help myself. I'm a recovering English instructor.
