Author Topic: Best keycaps for a curver layout (like MS Sculp)  (Read 2774 times)
Offline mamcx
« on: Wed, 08 June 2016, 13:09:05 »
I'm researching how made a keyb like the MS Sculp. Is a curved layout.
About keycaps I understand that sculped could be problematic. So I asked and direct me to:
http://pimpmykeyboard.com/key-cap-family-specs/
So look like is between LP FAMILY  and DSA FAMILY but wich? Or exist something that could be better?
Offline Niomosy
Re: Best keycaps for a curver layout (like MS Sculp)
« Reply #1 on: Wed, 08 June 2016, 17:00:16 »
If this is a keyboard for just you, take your pick, though LP would likely be closer to the MS Sculpt.  If for others, chances are people will put on whatever they want.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Fri, 10 June 2016, 13:47:58 »
I would think that spherical caps would work better in curved key wells and bent plate/pcb type applications. Just because they're rounded on the top. DSA?
