Author Topic: Will RealForce adopt the Cherry MX Compatible Stems for all their keyboards?  (Read 25497 times)
Offline les_garten
Woudn't that be awesome!
« Last Edit: Fri, 10 June 2016, 13:18:57 by les_garten »
No not really. Stock topre PBT are great and add a lot of value when considering the initial price of realforce and hhkb boards.
It might be great though to give people the option and sell MX compatible boards at a lower price.
And a board like the type heaven would be OK with MX compatible stems.
Offline les_garten
I just saw that they RealForce is releasing a board with MX compatible stems and was wishing they would just convert all stems to them.  It would seem a smart move on Topre and Realforces part.
Offline Floody
  • Formerly Flood
  • But is it?
I would think the decision would be with the manufactures not Topre.
Offline les_garten
Yeah, I really meant to say RealForce
Fixed it
Offline zslane
Sure, but Topre will have to put something on these MX-stemmed RealForce board as stock keycaps. I'm sure they are capable of deploying the same calibre PBT keycaps they currently use, but with MX stems.
Consequently, there is virtually no benefit to sticking with the old stem style going forward, is there?
Offline FrostyToast
  • Litshoard
As long as they will be able to modify the stems for type s keyboards then it shouldn't be too much of an issue.
One more thing to note is that caps fit better on MX stems as topre caps have some wiggle room when they click on giving a less solid feeling.
I don't know if anyone else has noticed this with the MX stems since I haven't seen anyone comment on it yet.
Quote from: elton5354
Offline zslane
Silencing a Topre switch is purely and internal issue, is it not? The shape of the stem tip shouldn't play a role. I can't think of any reason why they wouldn't be able to make MX-stemmed Topre switches "S"ilent as well.
Offline les_garten
It's quite an indexing system...
Offline Tangtawan
i went to Realforce booth at computex 2016 last week, they have their new Realforce RGB keyboard with Cherry MX sliders and adjustable activation point on show, I also heard that it will be on sale soon. So i guess they will go with MX compatible stem from now on..
But I have to admit that I kinda like the original realforce more; the new Realforce RGB one went with ABS doubleshot and the board quality feels a lot cheaper compared to the original 104U & 87U
« Last Edit: Fri, 10 June 2016, 16:29:19 by Tangtawan »
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
Offline muon
i went to Realforce booth at computex 2016 last week, they have their new Realforce RGB keyboard with Cherry MX sliders and adjustable activation, and i think that it will be on sale soon. So i guess they will go with MX compatible stem from now on..
But I have to admit that I kinda like the original realforce more.
Is there a significant difference in feel even if you don't change the activation point?
Offline Tangtawan
I'd say that it no longer feels premium like the original Realforce 87U & 104U, since its RGB board they are switching from PBT keycaps to ABS Doubleshot, the chassis is similar to those Ducky One or KBTalking108 boards. Typing on it feels more like the original novatouch (ABS keycaps), just overall build quality and ABS keycaps causing it to be less enjoyable to type on- the switch itself feels exactly the same, and that tactile bump only happens at one spot regardless of your activation point setting.
I do have a short video of the staff demonstrating the adjustable activation point recorded with my phone, will upload soon.
« Last Edit: Fri, 10 June 2016, 16:48:11 by Tangtawan »
Offline zslane
That all makes sense to me.
I guess the trade off for RGB backlighting is ABS instead of PBT in order to get the double-shot legends? They could have gone with "Vortex" translucent double-shots in PBT but I guess they chose not to. Oh well. I wouldn't be keeping the stock keycaps on regardless of what they were.
This new keyboard will be in ANSI 108 layout, correct?
Do we know what case colors will be available?
Let's hope not.
HHKB will be the last true keyboard if RF betrays the keyboard gods and puts cherry **** from now on.
Offline HeeCh2ei
  • qdrw
Let's hope not.
Agreed.
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline lancre
Speaking as an owner of a Realforce and a Novatouch, in my opinion: no, they won't. And no, it wouldn't be awesome.
The custom keycaps are fine on a Novatouch (or indeed Topre's newest venture into the Cherry compatible stem market). But I'm not convinced of the appeal on Realforce boards.
I think that part of the charm of the Realforce boards is that you either use their naff legends and their nice PBT caps, or you don't use them at all. It's part of what makes them a little weird and appealing.
I'd also be worried that what has happened on the Novatouch (I'm referring to the clack of the slider hitting the top of the housing, which has created a dental band aftermarket for this board), would carry over to Topre boards.
 Realforce 104UW          Dell AT102W             NMB RT8255C+                   Omnikey Ultra-T
Offline sth
  • 2 girls 1 cuprubber
Let's hope not.
MX ain't the only switch that uses mx-spec cruciform (marquardt and futaba... and of course the heavenly MY)
Offline bocahgundul
  • a seal
I see that realforce is making a new realforce RGB board that uses cherry mx stem so yeah
Offline FrostyToast
  • Litshoard
In order to account for the increase of material with the o rings the base of the stems have to be thinned out so as to not affect the travel.
This means that the moulds for MX compatible silent sliders will have to be different.
Topre PBT keycaps are great - but they needs to makes more of them!
Offline zslane
Wow, I couldn't disagree more. Nearly the entire appeal of a RealForce comes from its Topre switches and its build quality. The stock keycaps are entirely besides the point.
If you look at the history of custom keycap group buys, you will find that 99% of them have MX stems. That means that virtually the entire custom keycap community needs/uses boards with MX stems. The NovaTouch is the only Topre-like keyboard that can take all those millions of custom keycaps, and it only comes in TKL format and only in black. Moreover, there is little evidence that Cooler Master has any interest in continuing the product line, much expanding it into other layouts.
That means RealForce is poised to take the entire Topre+MX market for themselves. This is fantastic news for everyone who owns any of the many fantastic keycap sets that have come out these last several years and also want that Topre experience.
For many of us, typing nirvana will only come when we can put SA keycaps onto genuine Topre switches. The stock PBT caps that come on any board are eBay fodder and nothing more, and contribute zero "charm" to a board whose primary value lies in its switches.
Offline kasakka
I really hope they go MX. There is no reason to have two different, incompatible systems for attaching keycaps. Surely Realforce PBT caps could be made exactly the same but with a different stem.
Topre switches are great but the limited options in keyboards are a bit annoying.
Stock topre pbt caps are premium quality caps and that is part of the appeal.
They don't need to be replaced like almost all stock MX caps.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
Soooo... About that ABS spacebar....
Offline Moistgun
  • Slippery When Wet
Does it really NEED replacement
Sent from my local payphone
Offline zslane
True, they don't need to be replaced. But most custom keycap buyers don't buy sets because the stock caps on their boards are bad. They buy them because they offer colorways, novelties, and profiles (spherical in particular) that stock keycaps don't.
For example, there isn't a Topre keyboard in existance that comes with 7bit's SA Space Cadet set as stock keycaps. Consequently, any RealForce board I might buy would need its stock keycaps replaced. I'm sure there are plenty of folks who feel similarly (albeit about some other custom keycap set).
Offline Moistgun
  • Slippery When Wet
A SA space cadet swap is completely different than swapping a black abs bar for a black pbt bar lol XD
Offline _PixelNinja
  • C=Q/V=ε(A/t)
Do we really NEED to spend this much on keyboards?
Seriously though, I dislike ABS keycaps and it is a shame to have a spacebar made of an inferior polymer (in terms of wear resistance) in relation to the rest of the keycaps on these boards; it bothers me to know it will degrade sooner rather than later. If it does not bother you, then more power to ya.
Oh they would definitely benefit from using the pbt spacebars that matt3o had made.
I didn't believe in them until I tried them.
Offline zslane
Apologies for the confusion. I was responding to Spamray, not you. I should have quoted his post, but I didn't realize folks were replying so fast and furious and that my post wouldn't immediately follow his (for proper context).
Offline Moistgun
  • Slippery When Wet
Its a good point nevertheless in regards to the thread
I think it's great if realforce provides the MX compatible stems as an alternative for those desiring to use MX compatible caps but I don't think there should be a complete swap over.
I don't think they will still offer quality stock caps with MX stems.
The point I'm making is the stock topre pbt caps are much better than what you will find on other stock keyboards and are actually worth using.
 I also think you will find those making an argument that stock topre stems provide a different feeling.
I do agree most stock MX caps are garbage.
And no keyboard comes stock with 7bit's SA caps :P
« Last Edit: Sun, 12 June 2016, 11:54:56 by SpAmRaY »
Offline les_garten
There are choices with the MX stems.  Some Not so good, some great.
Not many choices with the Topre stems as we know.
I would suspect that the MX compatable stems could be more solid.
I don't see how going MX compatible would be a bad thing.
« Last Edit: Sun, 12 June 2016, 12:43:45 by les_garten »
Offline zslane
I confess I don't understand why they wouldn't (or couldn't) offer quality stock caps with MX stems. Could you explain this to me?
As for those making an argument that the Topre stems feel different, I'm not sure I understand that either. What are they comparing it with? A NovaTouch? Is that really a valid comparison in this case? I mean, it's not like the NovaTouch switch is a Topre switch with an MX stem. It is a Topre-like switch (a clone, if you will) with an MX stem. The stem type isn't the only thing that makes them different from each other...
I don't doubt they could make mx compatible caps of the same quality as their current stock caps I just don't think they will.
Also the novatouch is topre with mx compatible stems just in a coolermaster case with crappy stock keycaps, the PCB says topre on it, sure the springs aren't gold they are silver and the sliders are mx compatible but the internals are topre.
The point being the way the keycaps will physically attach to the stem will be different therefore the feel will be different.
Now boards like the royal kludge and noppo I would call a topre clone as they came up with their own pcb, different stem mechanism, different domes etc.
Offline les_garten
Every review I read about the Novatouch said that the Novatouch has a genuine Topre switch.
Realforce  just put the same hybrid switch on a RealForce didn't they?  The RGB one
I wanted to point out the topre mechanism isn't a discrete switch like mx switches just so that is clear as not everyone realizes that.
It is a sandwiched mechanism of pcb, spring, rubber domes and switch stem with a plate mounted housing or in the case of the hhkb the top case is the stem housing.
Offline zslane
Why not? What caps are on the prototype they showed recently?
Gotcha.
Offline les_garten
It's strange, wasn't everybody wishing for this?
Who hasn't seen one of those awesome, well made, and expensive quality sets that they wish could be added to a Topre?
Looks like a win-win situation if they would adopt that stem universally.
Offline zslane
I certainly was!
I think it comes down to this. If you buy a stock MX keyboard you most often need to replace the caps because the stock keycaps are garbage however when buying a stock topre keyboard you don't have to buy new keycaps because the stock keycaps are great.
Just wanting to intermix mx caps and topre to have a pretty keyboard is fine but shouldn't be the default answer.
Again if I buy a topre keyboard its good right out of the box whereas most mx keyboards will automatically need better caps.
I'm not sure but as the board shown was backlit they'll be backlit compatible which normally means they aren't quality caps to begin with. Now that isn't saying they couldn't be but unless they actually release it we won't know.
Last year they advertised a type heaven with the same stems and it was backlit but it never came to market.
Offline les_garten
It seems that the majority of modding is modding for modding's sake.
Will that sound better if I throw in two more instances of the word modding?
Offline les_garten
Offline les_garten
Double post
Let's hope not.
but it's the most popular.
Offline Hypersphere
A strength of the original design is that the keycaps integrate perfectly with the Topre switches, completing the functional unit. Given the variability of keycaps in the Cherry mx world, mixing these with Topre switches will likely result in some functional mismatches.
Offline zslane
Well let's be honest, having a pretty keyboard is pretty much the only reason to intermix MX caps with Topre switches. And apparently it is a pretty popular notion, otherwise Topre wouldn't bother with this.
It will be interesting to see how sales of the MX-stemmed RealForce compare to the original-stemmed RealForce in the years ahead. The old stems could end up going the way of the vinyl record...
Offline lancre
I don't think it's entirely besides the point... because if you change the caps to cherry compatible, then you change the sliders. You change the sliders, you change the tooling. They're going to end up using the tooling they had for the Novatouch... the board that created its own aftermarket in dental bands.
Anyway, weren't Topre bringing out a new keyboard with MX sliders this year? It'll be interesting to see how the reviews for that one stack up against the Novatouch.
I'm just playing devil's advocate to a certain extent, but I'm not all that convinced about the build quality of the Realforce... it's all of 4 plastic latching tabs that hold together a keyboard with a metal plate in it. No joke, I had to send mine back once because some of the catches opposite the latching tabs had snapped off in transit. I would tentatively suggest that the Leopold is the best of the builds for this one. I'm typing this post on a Dell AT102W and it feels like I can throw it down the stairs with more confidence than I could throw a Realforce down the stairs.
Offline supamesican
Let's hope not.
honestly I expect them to offer both.  Granted theres other options for true keyboards, unicomps exist still
Offline Hypersphere
Let's hope not.
Unicomp may be making an effort to keep the dream alive, but some would contend that their products are a pale imitation of the real thing.
