Author Topic: [GB] Noxary X60 V1  (Read 671946 times)
Re: [IC] 75%, HHKB & 60% Customs
« Reply #50 on: Mon, 13 June 2016, 18:51:14 »
The longer one looks awkward. Will the shorter weight cause some sort of balance issue when lifting it? Not that you'd be lifting an alu case like that often, but still.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #51 on: Mon, 13 June 2016, 19:53:36 »
Definitely the shorter, fatter one. As romevi said, the bottom one just looks awkward.
Offline JulienC
  • Esc Artist
« Reply #52 on: Mon, 13 June 2016, 20:59:37 »
Interrested in the HHKB-style case, filled the questionnaire.
HHKB
Offline loud_asian
« Reply #53 on: Tue, 14 June 2016, 00:05:28 »
The top one, it leaves more room for engraving
Offline gadzkun
« Reply #54 on: Tue, 14 June 2016, 00:12:31 »
+1 bottom  :thumb:
can you make the side of bottom case have handle like lz rv
Offline xondat
  • i'm not a star
« Reply #55 on: Thu, 16 June 2016, 18:27:10 »
I've decided how I'm going to finish the design. I will have next to finished pictures of it tomorrow.
Offline loud_asian
« Reply #56 on: Thu, 16 June 2016, 18:47:02 »
Yesss, I can't express how excited I am for this custom
I'm even thinking about picking up multiples of the HHKB
« Reply #57 on: Thu, 16 June 2016, 18:50:49 »
Looking forward to tomorrow's showing!
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #58 on: Thu, 16 June 2016, 20:55:25 »
Will definitely follow the development on this one.
Offline Waateva
« Reply #59 on: Thu, 16 June 2016, 21:05:53 »
I like the bottom weight shape and I would definitely be interested in a 75% board
Offline xondat
  • i'm not a star
« Reply #60 on: Fri, 17 June 2016, 09:39:40 »
Find the rest of the images here: http://imgur.com/a/OGAa2
So this is the HHKB finished in my eyes. I had a total of 41 responses to the questionnaire, and 20 peoples favorite was the HHKB. The results I got helped a lot with the design process and the 3rd remodel that I did, so a lot of the things from it are reflected in the keyboard itself. I'm sure there will be minor tweaks but that's it as far as any big edits or design decisions go. However I may reduce the outside fillets to 1mm instead of 2mm, creating a less curvy look, but I'll see how it goes down as it's pretty split. Over the next couple of days I'll be remodeling the 75% layout - it will look the same as this. For now, I'll be working on quoting and seeing what I can do.
« Reply #61 on: Fri, 17 June 2016, 09:51:47 »
xondat, this looks absolutely marvelous.
Offline Saiph
« Reply #62 on: Fri, 17 June 2016, 10:49:20 »
Looks great! Can't wait to see your 75% redesign.
Offline R4WBIT
« Reply #63 on: Sat, 18 June 2016, 14:47:47 »
Looks absolutely amazing! 1mm instead of 2mm in the edges would look better imo, otherwise as said, great design. Hope you finish this project  :D
Offline loud_asian
« Reply #64 on: Sat, 18 June 2016, 21:59:15 »
2 mm is needed for the edges since it will be where the screw holes for the plate will be. If you check out the kmac happy, it doesn't look too bad with the bigger edges
whoops
« Last Edit: Mon, 20 June 2016, 18:03:39 by loud_asian »
Offline bocahgundul
  • a seal
« Reply #65 on: Sat, 18 June 2016, 22:08:31 »
1mm fo sho
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #66 on: Sat, 18 June 2016, 23:04:07 »
+1
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Minha
  • I Don't Want To Die Like Cobain
« Reply #67 on: Mon, 20 June 2016, 01:41:52 »
Any possibility of making the angle of the case higher?
Offline SixtyLife
« Reply #68 on: Mon, 20 June 2016, 01:55:48 »
love the hhkb. please do not make the angle any higher.
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline loud_asian
« Reply #69 on: Mon, 20 June 2016, 03:07:39 »
PLS NO
using my viper for extended periods of time kills my wrists
Offline 500_pts
« Reply #70 on: Mon, 20 June 2016, 03:12:16 »
In for hhkb style.
REALFORCE 86u | HHKB Pro 2 | Filco TKL| Filco TKL | Leopold TKL | KBT Race
Offline Minha
« Reply #71 on: Mon, 20 June 2016, 04:01:36 »
I like the steeper angles :(
« Last Edit: Mon, 20 June 2016, 04:04:54 by Minha »
Offline xondat
  • i'm not a star
« Reply #72 on: Mon, 20 June 2016, 08:02:37 »
This isn't true - the fillets are the curves on the vertical edges. I can change this how I want
Not really, I quite like 8 and so does everyone else. What angle are you looking for?
Offline bocahgundul
  • a seal
« Reply #73 on: Mon, 20 June 2016, 09:23:29 »
1 mm and 8 degree das it
Offline thebeae
« Reply #74 on: Mon, 20 June 2016, 11:01:59 »
Looking great! Cant wait to see the 75% :)
Offline loud_asian
« Reply #75 on: Mon, 20 June 2016, 18:03:08 »
If that's the case, hit me with those thin edges
Offline scubaste
« Reply #76 on: Mon, 20 June 2016, 18:48:26 »
I don't see how I could pass up on the HHKB layout. Great work on the design.
Offline xondat
  • i'm not a star
« Reply #77 on: Mon, 20 June 2016, 19:08:17 »
Small update from the emails with the shop.
  • 6061 will be used over 7075 as the latter is about 20% more expensive.
  • The cost increase between different anodizing colors is minimal so perhaps several colors will be offered.
  • Colors need to be kept "broad and basic" although any color can be done, providing it's a primary or secondary.
  • Laser etching the brass weights is possible with a small percentage increase in price.
  • A brushed finish on the weight is possible, along with nickel plating.
  • Everything will be done at the one shop, which allows quality control to be at its highest.
  • I'm looking at having 25 kits made, and deposits are looking likely.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #78 on: Mon, 20 June 2016, 19:52:43 »
Do we know how much a kit (whatever is available) will likely be priced at? Rough estimate?
Offline loud_asian
« Reply #79 on: Mon, 20 June 2016, 19:54:06 »
Any idea when you'll start taking deposits? I'd hate to miss out on this
Offline xondat
  • i'm not a star
« Reply #80 on: Mon, 20 June 2016, 20:04:58 »
Not going to make guesses. There's prices that I want it to be at but saying that doesn't mean it will be therefore I'll post the price when I know.
As soon as I know the cost of the prototype and the amount that have to be made for a realistic group buy cost.
Offline SixtyLife
« Reply #81 on: Mon, 20 June 2016, 20:32:47 »
seems like people are confusing fillets for bezels. I'm personally a fan of what you have in the current mockups and think it looks good with that bit of roundedness on the outside edges.
pic of fillet for those who may be confused:
Offline xondat
  • i'm not a star
« Reply #82 on: Tue, 21 June 2016, 04:23:34 »
I figured this was happening too.
Offline Diokhan
« Reply #83 on: Tue, 21 June 2016, 04:38:22 »
This looks sexy as hell
Sent from my Nexus 6P using Tapatalk
Offline xondat
  • i'm not a star
« Reply #84 on: Tue, 21 June 2016, 08:59:21 »
Expecting numbers today, been in communication with the shop all day.
Offline Phenix
« Reply #85 on: Tue, 21 June 2016, 13:28:32 »
I also vote for fillets!
Winter is coming.
Offline xondat
  • i'm not a star
« Reply #86 on: Wed, 22 June 2016, 18:39:09 »
I've decided that I'll be producing enough to keep the price down instead of keep the numbers low for no reason. Aiming around the $350 mark though.
Offline loud_asian
« Reply #87 on: Wed, 22 June 2016, 18:43:53 »
At least its not $400  :p
I'm still interested in getting at least one of these
Offline xondat
  • i'm not a star
« Reply #88 on: Wed, 22 June 2016, 18:54:07 »
Oh I want the price as low as possible too but there is only so many that will buy it :))
Offline raymogi
« Reply #89 on: Wed, 22 June 2016, 19:10:37 »
I need that 60% WKL.
Please feed my addiction.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #90 on: Wed, 22 June 2016, 21:23:43 »
Is that $350 with PCB or without?
WTB/WTS/WTT ---->
Offline dannrawr
« Reply #91 on: Thu, 23 June 2016, 04:06:37 »
if only i have more moneh :'(
WTF any Bruce, Cosmonauts
« Reply #92 on: Thu, 23 June 2016, 09:48:34 »
Ouch. A little bit higher than I thought, especially since I want only the case and plate.
What PCB will it use? I can't imagine the PCB will knock off that much.
Offline billnye
  • ability man
« Reply #93 on: Thu, 23 June 2016, 10:18:51 »
Good looks my man.
Offline xondat
  • i'm not a star
Re: [IC] HHKB Custom (XK3)
« Reply #94 on: Thu, 23 June 2016, 10:52:46 »
So doing 25 is stupid. It roughly works out around $650 per case at 25. Absolutely not doing that little. Instead, 50+ will half the price and make it much more viable. However there might have to be sacrifices such as no switch modding on the plates, no engraving or even changing the weight design/removing it completely. Reaching 50+ is insane for a keyboard, especially since they're ~$320. Whether this is possible - I don't know. I guess the only way to see is to try.
In order to have the prototype made, I will need to raise the base cost or take deposits. I can see the minimum being $340 at this current point in time. This means that deposits would be $20, and I would need 50.
Please fill in this poll so that I can get working on it and get the price as low as I can.
POLL HERE
Offline xondat
  • i'm not a star
« Reply #95 on: Thu, 23 June 2016, 14:17:32 »
The weight design will be changing, I'll be getting quotes for both no weight and an optional weight and comparing how different the prices are. I'll be getting a quote for a plate with no switch modding, simply out of interest. Engraving is something that probably won't be done as the cost compared to the amount of people that will want it just doesn't make sense for the others.
Offline loud_asian
« Reply #96 on: Thu, 23 June 2016, 14:27:56 »
Thanks for the update xondat  :thumb:
Have you thought about contacting vendors and seeing if they could potentially pick up a couple of orders?
Offline ramnes
  • T fou, mec?
« Reply #97 on: Thu, 23 June 2016, 14:34:14 »
Democracy sucks.
I want an engraved weight, and visible from outside. :'(
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #98 on: Thu, 23 June 2016, 16:29:55 »
Just noticed the thread name was changed. Will there even be a regular 60% option now?
WTB/WTS/WTT ---->
Offline Diokhan
« Reply #99 on: Thu, 23 June 2016, 17:07:39 »
Democracy sucks.
Same here man
